Old 12-28-2007, 08:38 AM
comptonking comptonking is offline
Send a message via AIM to comptonking
PLZ help need to get my window up w/o switch!
Ok i have a 98 4-door grand prix and the switch to the window went out so i can only roll down the window. I had this fixed once and the mechanic took the plug from the back of the window switches and crossed some wires and rolled up my window, i cant figure out what wires it was there are 5 i believe. Any help would be great i live in MN and its freezing!
Old 12-28-2007, 09:27 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: PLZ help need to get my window up w/o switch!
Which specific window?
Double check your wire color coding to be sure but on the switch there should be a yellow color coded wire which is the 12 volts from the power window circuit breaker. At the window motor there are two wires a brown and blue (either light or dark blue). Brown is down. The blue is up. Look for these same wires on the window switch. For example if it is the driver's side window jump the yellow wire to the blue either at the switch assembly or motor. Window should go up. If not try the brown wire.
Timeslip 08/12/06
AF Community Guidelines
Old 12-28-2007, 01:26 PM
THANK YOU!!!!! i'll let u know how it works
Old 12-28-2007, 02:48 PM
That didnt work! I think i need to cross three? theres 2 blue ones a yellow one a black one and a brown wire. PLZ HELP!!!
Old 12-28-2007, 02:49 PM
Oh yea and its the front drivers window!
Old 06-11-2008, 06:51 PM
jnfigueroa jnfigueroa is offline
I'm having the same problem, I really don't want to buy a switch just yet, so do you know how to open the switch, I traing to clean all the contacs
thank you!!
