Fuse Box on 1986 Nissan?
This has got to be a common problem among these trucks. I have a 1986 kingcab. Several fuses are loose in the fuse box. It looks like the contact points for the fuses have bent so that the fuses will not fit tightly. I had to build up the contact points on the fuel pump fuse to keep it in and the fuel pump running. I really don't like this solution.
Has anyone else had this problem and if so, what can be done about it? Several other fuses are loose as well. Thanks |
Re: Fuse Box on 1986 Nissan?
remove the fuse and very carefully bend them back into postion..
[email protected] |
By the way, thanks for the info on the starter relay. I will check that out. Also, Zane Grey is the name of a well known western author way back when. Does your screen name have anything to do with him? Thanks |
they are copper and will bend easily..
use a set of needle nose pliers.. i repeat ...carefully. zanegrey is my name...my grandparents knew the author and were fans..
[email protected] |
