Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-27-2007, 10:19 PM
93-240SX-COUPE 93-240SX-COUPE is offline
Send a message via Yahoo to 93-240SX-COUPE
What is an open diff?
I've been looking at some drivetrain parts and how some of the 240's came with an open diff, i think its just s14's, but what exactly is an open diff vs an lsd vs vlsd?
I've searched this forum for "open diff" but none of the other threads really explain it.
Old 12-28-2007, 07:59 AM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: What is an open diff?
im going to give you a quick tutorial on this subject.
open diff means only 1 tire ever spins (evaaaaa!!!)
now vlsd is open diff when going around sharp corners (allows the clutch packs that are in the diff to break away at certain ft lbs to reduce noise and vibration)
...so in general vlsd have clutch packs inside the rear diff that allows both wheels to hook up.
these can wear out, there fore if you get a vlsd make sure its a low mileage one
~Nick
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 12-28-2007, 11:38 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Its my understanding (so please correct me if im wrong) a VLSD uses fluid to lock the axel (spins both tires) where as a typical LSD uses a clutch pack. and an open Diff uses spider gears to put power to the tire with least resistance. and yes, you can spin both tires with open diff.. my cutlass was proof of that
Old 12-28-2007, 03:19 PM
Well since my car only has one tire spinning then does that mean that I have an open diff?
And if so then pretty much every car has at least an open diff which basically means that it doesnt have an lsd, right?
Old 12-28-2007, 03:44 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Yes.
Every car has an open differential, unless of course it has an LSD.
Old 12-28-2007, 05:25 PM
Got it.
"Open Diff" is just a clever way of saying "your car doesnt have an LSD BUT it does have an open differential" (which basically means it doesnt have anything or do anything cool)
Old 01-03-2008, 01:09 PM
slideways...'s Avatar
slideways... slideways... is offline
right. theres a few different kinds of differentials, VLSD uses the viscous properties of oil to help convince the wheels to spin the same speed, but oil isnt as strong as metal or friction surfaces. thats why a VLSD will act like an open diff if the fluid is old/abused.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 01-05-2008, 02:23 AM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
open diff is the poor man traction control... that is why its standard.
ur grandma will not know what to do when the back of her car will come out while she is making a U turn! (for us its he fun part! for her it a life threatening situation)
open diff is gay but it makes the car act as FWD and it saves gas+ clutch + tiers too...
get a LSD for Gods sake, any RWD car NEEDS LSD 1st then everything else later!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
