Vent Solenoid P0446
Got a code P0446 today and was wondering what could have caused it? I have a 2002 z71 with 5.3. Also where is the vent solenoid located and what does it do? I cannot tell what is wrong with my truck as it runs fine. Thanks!
Re: Vent Solenoid P0446
This is just what I would try before replacing the vent solenoid. First I would turn on the ignition, test the 2 wires at the solenoid. One should have 12v the other should be a ground. If you have that then I would try to verify if the solenoid was stuck closed. (I tried unplugging mine and plugging it back in to see if it would make a clicking noise, but I could not here anything.) With out verifying the condition of the solenoid you run the risk of replacing it and the blockage being somewhere else.(they charged me $80 for mine so it is not a cheep part to gamble with) I am not a tech, so take my advice with a grain of salt, I hope this helps.
maybe this will help.found this bulletin.vent solenoid on these get dusty and plugged.you have to relocate vent solenoid and replace it.it's outlined in this bulletin.maybe will help in your diag.Subject:DTC P0446 (Restricted/Blocked EVAP Vent Path) Set, Service Engine Soon (SES) Lamp Illuminated (Replace Evaporative Emission (EVAP) Vent Valve Solenoid Assembly with Service Kit) #02-06-04-037C - (04/17/2007)
Models:1999-2007 Chevrolet Silverado (Classic) Models 1999-2007 GMC Sierra (Classic) Models This bulletin is being revised to update the warranty information to include additional labor time for diagnosis. Please discard Corporate Bulletin Number 02-06-04-037B (Section 06 -- Engine/Propulsion System). <A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1962238&psdid=271&evc=sm#ss1-1962238">Condition Some customers whose vehicles are operated in dusty type environments, such as farming or mining off-road type applications, may comment about the illumination of the instrument panel SES light, with a DTC of P0446 (Restricted/Blocked EVAP Vent Path) being set. <A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1962238&psdid=271&evc=sm#ss2-1962238">Cause Dirt and dust intrusion into the EVAP canister vent hose assembly, resulting in restricted air flow, may cause this condition. <A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1962238&psdid=271&evc=sm#ss3-1962238">Correction After following the Service Information diagnostics for P0446 and determining that the EVAP canister vent valve is the cause of the SES light, replace the existing EVAP canister vent valve assembly with a new assembly. This new assembly is a sealed unit that is designed to be vented through a remote filter box. To ensure correct installation, follow the procedures below.1999-2003 Model Year (Use Service Kit P/N 19152345)
this is an excellent explanation of this failure great pictures ! thanks
Does anyone have any idea how much this kit costs? Probably couldnt hurt...
