Old 12-25-2007, 05:24 PM
jhines037 jhines037 is offline
2000 S-10 High Beam Will Not Work
My driver side high beam will not work but my day running light works fine. I have changed the bulb twice and my pass high beam works fine. DOes anyone know what might be wrong or have had the same problem
Old 12-26-2007, 03:28 AM
16th hippy 16th hippy is offline
Re: 2000 S-10 High Beam Will Not Work
not work at all or just dimly lit with hi-beams on? check usual suspects, power and ground to connectors and work your way back from there,
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 12-26-2007, 02:50 PM
Not at all my brother inlaw and I have been looking thinking it might be a broken wire
Old 12-29-2007, 04:22 AM
ok, check for power to plug, and check the ground, you will have to work your way back from there, but sounds as if that is the culprit since other side works
Old 12-29-2007, 10:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
With or without ZR2 light setup?
Most of them have a seperate fuse for right and left side.
Check all fuses first.
If fuse not blowed the g3et a good wiring diagram and a old 12 volt test light.
And trace the light circuits.
MT
MT
