Old 12-24-2007, 11:06 PM
adamoats adamoats is offline
rad doesn't get warm
my '96 cavalier heated up the other day so we changed the thermostat. the car still heated up but no heat came out inside the car. we vented the steel line and finally got heat inside the car. we also vented the plug beside the engine but the rad fan still wont' come on. the rad still is cold on both hoses as well. we pulled the water pump out and its fine. the guage goes up and engine will overheat if we kept it running. any ideas? is it an air lock? rad plugged? we used an air compressor to blow through the lines and it spews out the other hose. any ideas we really help
Old 12-26-2007, 03:15 AM
16th hippy 16th hippy is offline
Re: rad doesn't get warm
either pump is not fine and not moving water or there is a big blockage in a hose, in engine or somewhere is system. is NOT reccomended for long term, but try removing thermostat and see if problem goes away.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
