Old 12-24-2007, 08:19 PM
CarolinaCavy CarolinaCavy is offline
Stupid Cavalier
I have a 1996 Cavalier Z-24 and Friday night my cat and restinator was glowing red so I took it the cat went bad. Ok so I had the cat changed and now the car lopes real mad and sounds like a pissed off go kart. I checked the ICM and the ignition along with the egr value changed the O2 sensor and I let it run even though it was still running rough and the new cat got red again so I said maybe the resinator is stopped up but no the damn thing is still running bad any suggestions would be appericated.
Old 12-26-2007, 03:18 AM
16th hippy 16th hippy is offline
Re: Stupid Cavalier
what motor is in the z-24....is late and i can;t remember to save my life. leaky injector/no spark to one or more cylinders. sounds as if alot of fuel is getting into cat and burning, hence the glowing red. is CEL on/flashing as all?
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 12-26-2007, 09:48 AM
Re: Stupid Cavalier
The motor is a 2.4L Quad 4. I checked the no. 1&2 spark plugs and the spark wasn't as strong as the no. 3&4 spark. Do you think that is the problem maybe not the spark plugs but a coil pack or something.
Old 12-29-2007, 04:01 AM
Re: Stupid Cavalier
pull the wires off 1&2 and look at the terminals on the coil pack, if corroded, then replace as that will inhibit spark. plugs been changed recently, and wires?
Old 12-29-2007, 05:41 PM
Re: Stupid Cavalier
Yeah all the ingition has been replaced now and still doing the same thing. Thinking it my be the EGR value I dont know it's getting old fast.
