Old 12-24-2007, 06:02 PM
KrnAznEP KrnAznEP is offline
brake booster
when removing the brake booster to get to the master cylinder on the turbo models do i have to bleed the brakes because i unscrewed the hardlines? Was it also safe to use a penetrator to get the nuts loose?
Old 12-25-2007, 08:23 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: brake booster
I wouldnt remove the booster. It can be done without removing it.
Yes you can use penetrator to loosen the lines. And yes if you do remove the booster you have to bleed the brakes.
Old 12-25-2007, 11:55 PM
Re: brake booster
i opened one of the lines slightly like a drop of oil came out do you think air got into the system? i tightened right away once i saw oil come out.
Old 12-26-2007, 06:13 AM
Stealthee's Avatar
Re: brake booster
yes, as soon as the line is opened air can be introduced into system.
Old 12-26-2007, 02:04 PM
Re: brake booster
okk thanks a lot for your help man
