Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 12-24-2007, 08:50 AM
LISFISHER LISFISHER is offline
Turn signals and hazard out help!
1999 Galant, both turn signals out and the hazards do not work. I was told by the auto parts store there are 2 seperate flashers for the signals and the hazards, so I think that eliminates a bad flasher. What else should I be checking? If one of the bulbs is out would it make the others non-functional?
Old 01-13-2008, 02:32 AM
Lupis Lupis is offline
Re: Turn signals and hazard out help!
Have you checked your fuses in both areas (under hood, driver side under dash)?
Old 02-04-2008, 10:30 AM
dragomistu dragomistu is offline
First, check all fuses, then check for any power going down to both signal while turning the signal with key-on. If none, it's a bad signal switch. If all 4 turning signal is out, definately a bad switch?
Old 02-29-2008, 11:57 PM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
could be a faulty hazard switch as it disengages the indicators when hazard is activated
