Old 12-24-2007, 07:19 AM
mansopoor mansopoor is offline
coolant in oil
ok here we go!!! i believe i have a blown intake gasket causing the coolant to mix with my oil. I done a compression test on the motor, all the cylinder can out good so the head gasket is ok. here is the thing, as you know i now have the white milky crap running throught my motor, but its NOT thick like gup. Is there anyway to clean this out of the motor (eg. brake cleaner and a shop vac or something) cause I dont have $1000.00 to replace the motor (for a use one). I need to save this motor till spring when i can replace it. i live in Newfoundland, Canada and i need my 4X4
PLEASE HELP!!!!
Old 12-24-2007, 08:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: coolant in oil
The best cleaner is a a couple of oil and filter changes.
MT
