Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-23-2007, 11:44 PM
GreyGoose006 GreyGoose006 is offline
rear end confusion
so i know this is a completely NOOB question, but hey...
what are the different rear ends that can be used in a third gen camaro, and what is the best.
i might be confusing things, but i have heard 7.5", 9", 10 bolt, 12 bolt, 9 bolt, 8.5"...
how do i compare a 10 bolt and a 9" for example...
after this, i was wondering what rear gears can be used in each.
im guessing they arent interchangable, but if they are, which ones?
is positraction (or a derivitave of some kind) available in each?
how hard is it to change the gears in a rearend if i find the one i want with the wrong gears?
how do i identify what i have?
how do i identifiy what i find in a junkyard?
sorry for so many questions, but i never understood this whole buisness, and i need someone to explain it
thanks
Old 12-24-2007, 12:23 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: rear end confusion
A 9" isn't going to be factory for your car (it's actually a Ford rear end), nor will a 8.5", or a 12-bolt. You're looking likely at a 7.5", 9 or 10 bolt.
There should be a Posi diff for any of the aforementioned axles except the 9" - there'll be a limited slip option for that I am sure, but Posi is a GM term.
You're better off asking in the Camaro/Firebird section.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-26-2007, 03:56 PM
well i was also looking for general info rather than just what i can put in a specific car.
Old 12-27-2007, 08:33 AM
MrPbody MrPbody is offline
AF -Advisor
Curry, Inc. makes a 9" Ford that bolts right in. It can include rear discs, as well. Moser makes a 12-bolt that bolts right in, discs available, too. Both of these are BIG money (in excess of $2K). Worth it!
As far as I know, the 7.5" is the only one that "bolts right in", except the aftermarket offerings.
Posi-Traction is Chevrolet's "brand name" for the GM limited slip differentials. Pontiac calls their's "Safety Trac", but it's pretty much the same clutch-type rear. The Ford is called "Traction Lok" and the MOPAR is "Sure Grip". All of these are brand names for what is generically called "posi", or "limited slip".
There is also a ratchet-type differential known as "Locker", made by Detroit Machine. It's tougher and more effective than any of the clutch-types, but action is quite harsh, and they're a bit noisy.
A spool (solid center section) is called for if drag racing, but not recommended for a street car.
Jim
Old 01-06-2008, 11:49 AM
and what does all this mean?
what is the meaning of 10 bolts and 9 inches...
come on people, is this really that hard to understand?
i want info
Old 01-07-2008, 10:04 AM
silicon212's Avatar
Confoundingly Lucid
"10 bolt" refers to the amount of bolts which hold the ring gear onto the carrier. Not the amount of bolts that hold the diff cover on - although GM usually makes these two the same.
9" refers to the diameter of the ring gear.
Old 01-08-2008, 11:43 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
If you're that lost with "rear end 101" maybe you shouldn't be working on your own car. I used to carry around a card with all the GM rear axle codes on them and could tell easily what was what in the junk yards. Since then I lost it but the information should be easy to find with a Google search ot two.
Bob
Old 01-13-2008, 11:26 PM
i mean, duh, 10 bolt refers to how many bolts hold the ring to the carrier and 9" refers to the size of the carrier, but what i am asking is a simple question of how to compare them.
bob, you are obviously not helpful at all.
period.
Old 01-14-2008, 09:11 AM
AF -Advisor
Relax, dude. Compared to what? What Bob means is you need to read up and learn how they work, what the diferences are between them, and then you can compare them to see what will suit your needs. If you're just looking for a "what's the best" answer, there is no definitive answer. Each has strong points and drawbacks. What do you want to DO with it?
Jim
Old 01-14-2008, 09:53 AM
bobss396's Avatar
If I offended you, I apologize. I had mistaken you for many others here who should have someone fix their car for them or take a basic auto repair course first.
I see too many posts on the forums here and elsewhere where someone is going to hurt themselves or endanger others by working on their own cars to save a few bucks.
Bob
Old 01-31-2008, 12:52 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
wow what a moron
this dude is wasting your time
he obviously has no patience or manners
i wouldnt waste your time trying to help such a rude person
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
