Old 12-23-2007, 02:52 PM
bory bory is offline
97P/A a/c stop blowing cold air
hi, iam new to the site merryxmas to everyone ,problem a/c stoped blowing cold air ,airbag light, inside lights stop working also . help please and thanks in advance
Old 12-24-2007, 05:56 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 97P/A a/c stop blowing cold air
Have you checked all the fuses? Are you getting air out the vents and the AC fan (blower motor) running? You may also need to check refrigerant line pressure! (High & low side)
Old 01-08-2008, 07:44 PM
Elwood9270's Avatar
Elwood9270 Elwood9270 is offline
Had the same thing happen to my LeSabre. Maybe this will help or maybe not, but all I did is reset the PCM by unhooking the negative cable from the battery.
Old 01-08-2008, 08:02 PM
HotZ28's Avatar
AF Moderator Elite
Thanks for the input Elwood9270; this procedure may work on the early 90's PA's & LeSabre, but unfortunately this has never worked for me on the 94-up models.
The A/C controller is entirely different on these!
