Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 02-16-2003, 06:16 PM
OneHotV6's Avatar
OneHotV6 OneHotV6 is offline
Send a message via Yahoo to OneHotV6
Question Heater problem...
I have a '93 Sentra XE and the heat doesn't seem to be working that well. After the car gets to operating temperature, the heat blows out at a moderate temp even when I have the control all the way to hot. If I turn the fan to a higher setting, the temp gets cooler. I've also noticed the radiator cap doesn't get hot after driving around for a while and the bottom radiator hose isn't hot also. I changed the cap last year sometime and had the thermostat done about 2 years ago. Could the thermostat be stuck open or closed? The temp gauge needle goes to about 1/2 and stays there..
Any help would be appreciated, it's 12 degrees here!!!
Old 03-06-2003, 04:54 PM
OneHotV6's Avatar
Anyone??
2005 Ford Mustang GT
1993 Nissan Sentra XE
2005 Nissan Sentra S
My cardomain page
Old 03-06-2003, 06:27 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
sorry man I have NO clue what that could be...
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-07-2003, 05:55 AM
Nsane18 Nsane18 is offline
Make sure your coolant system is full, otherwise you get almost no heat as my old B12 did. If that doesn't work, change your thermostat. Remember, your heater core can't get any hot coolant if the system is low, or you have a clogged heater core hoses.
"Hey, didn't I see your car on a billboard for Uncle Ben's"
Old 03-07-2003, 10:07 AM
OneHotV6's Avatar
The radiator and overflow is topped off... I'm going to change the thermostat again. I had it out last night for about 45 mins (in 19 degree temps) and when I came back, the cap was a little warm, the top hose was hot but the bottom hose was cold..??? It's sort of like something is preventing the coolant to flow out of the bottom hose... Could the heater core be shot?
Thanks for the help!!!
Old 03-07-2003, 04:57 PM
Either the core is shot or the coolant lines running to it are clogged.
Old 03-13-2003, 09:58 PM
OneHotV6's Avatar
Well, I found out yesterday that the core is shot and needs to be replaced.. how hard is it to change out myself? And, where is this thing located??
Thanks!!
