Old 02-16-2003, 01:41 PM
vitalemt vitalemt is offline
Please Help Im confused
I have a 2002 z24 and i am having a problem the car has 7000 miles and i can put it in all gears(reverse Nuetral ETC!) but when i drive the car in DRIVE it acts as if i am driving with shifter in gear 2 or 1which is for going up and down hills its a automatic..it does not go into any other gears the rpms just keep going up ...any ideas would be very helpfull thanks!!!
Old 02-17-2003, 09:22 AM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
Hmmm.. When you slide the shifter down do you count the "clicks"?? Just a thought because sometimes the indicator says it's in a different gear then you're actually in. If you count three clicks you're in the right gear. I know that's stupid... but it's a possibility.
My only other thoughts are that 1. your TCC solenoid in the tranny isn't locking onto the driveshaft like it should (cheap and easy), or 2. your tranny is just faulty and your top gear is out(expensive).
Wish I could help more...
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 02-17-2003, 10:27 AM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
You could have other issues going on with the car that made it default into what they call safe mode. Best thing to do is take it to the dealer before anything gets damaged.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 02-17-2003, 10:40 AM
Pikachoo's Avatar
Hmm.. Interesting, I've never heard of that. Good info!!
Old 02-17-2003, 11:21 AM
I'm not sure if the Cav's have this feature but alot of the electronic transmissions have a default feature that will not allow certain things to happen if it sees a problem elsewhere. I don't do automatic trans' but I see alot of trucks default to third gear when an electrical portion goes south. These transmissions use several shift solenoids, pressure solenoids, tcc soleonoids and fluid temp solenoids to achieve everything. It only takes one false reading to give a strange result.
Shop Foreman
Corvette Specialist
L1 Certified
