Old 02-16-2003, 01:37 AM
ricerx ricerx is offline
Header Transfer?
Will DC Sports headers work on different blocks. Specifically would the model for a D15 work on a B18, or whatever is in a 91 CRX? I realize that it's not optimal, but will it at least work without causing more harm than good? I would hate to buy headers, have my car die, then waste them by not being able to put them to good use.
"You never heard of mind as perverted as mine" -Eminem
Old 02-16-2003, 06:44 AM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
no d series headers go on d series engines. and the same with b series engines. its like comparing apples to oranges
Old 02-16-2003, 05:18 PM
OK... So would headers made (by DC Sports) for a B16 fit on a B18, or is that like comparing Red Delicious apples to Grany Smiths?:licker:
Old 02-16-2003, 06:14 PM
strodda strodda is offline
i dont believe thats directly transferable either. but if youre worried about your engine crappin out on you, wait to get a header till after you get a new motor.
Old 02-16-2003, 08:42 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
I have heard that they won't fit cuz the block is slighty longer and the headers won't clear the oil pan. Try and find someone who has done a swap from a b16 to b18. But 4drlx is right D series stays with D and B series stays with B.
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
Old 02-17-2003, 07:43 AM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
You acuatually can transfer between a b16 and b18. I would know as I did it when I blew my b16a and got a b18c. The downpipe is the only difference, it has a little different of a cureve. It will clear the oil pan but will be a little close to it. And remember if this is a motor swap you have done that you are talking about, then the down pipe is gonna be a little lower than stock so be careful. I had a friend bottom out on his downpipe and it sheared off all the header bolts into his block.
Transfer Case Identification Project J10 General Discussion 2 03-26-2011 04:14 PM
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 09:16 PM
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 08:14 AM
99 DX header + test pipe sentoyang '96-'00 Civic 1 10-26-2009 02:34 PM
cali spec headers?? AHHKILLA Eclipse 2000+ 0 04-28-2009 12:03 AM
