Old 02-14-2003, 07:24 PM
Midnight Racer's Avatar
raising a truck
Ok well I plan on raising an old F150 kit I have.Its sitiing ic CSC right now to strip the paint.I know how to drop the suspension but how do you raise it?Any help would be appreciated.
This is the kit
Old 02-14-2003, 07:44 PM
zangief zangief is offline
Send a message via AIM to zangief
i used a revell chevy mudd something for the raise and used a siverado
http://www.revell-monogram.com/store...1&FromSearch=1
the outcome
Old 02-14-2003, 10:55 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
I saw an article one time in an old magazine about custom making shocks. They took one diameter of tubing and place a smaller tube inside of it with super glue. Then, they filled the ends with bondo and used smaller tubing to make the mounting hardware. That's one way you could make your shocks longer. you can also make larger leaf springs by using styrene to make scratchbuilt springs by layering the stuff in the same fassion as the stock ones. Just make sure they're the same length so that you can cut off the stock mounting hardware and use it on you scratchbuilt spring. That's one way to lift it. Another would be to kit bash a couple kits like Zan.
