Old 02-14-2003, 01:13 PM
erbinone's Avatar
erbinone erbinone is offline
D16Z6 Air Intake Question???
I just got my D16 in and was wondering which air tube & air box to use because my 88-91 one will not fit. Also, when buying an aftermarket one.... which do I buy 88-91 or 92-95?? I need answers to both asap. running w/ no filter!!!!.... thanks!
Old 02-14-2003, 01:36 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
I think that an 88-91 civic Si intake will fit because you still use the Si MPFI setup.
I'm Jordan
My car is the ugliest one on this board
Old 02-14-2003, 01:39 PM
erbinone's Avatar
No... I'm using the complete Z6 set up... intake & exhaust manifold & p28 ecu.
Old 02-14-2003, 02:25 PM
mightytexn's Avatar
I suppose you would use the 92-95 civic EX intake than, but I don't know how well it will fit inside the engine bay.
I'm Jordan
Old 02-14-2003, 02:33 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
i think the 88-91 aftermarket intake will work, i don't know about the 92-95 intake. the 4g intake is made for the si, which has the intake manifold in the same spot as the 4g si. so it should work just fine
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-14-2003, 03:32 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...does it not fit around the tb or something?
a 92-95 intake is gonna cut straight through the engine bay and will not really work unless you relocate your battery or move it over and jam it up against the radiator support w/o a tie down..
SOLD!
Old 02-14-2003, 03:49 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
92-95 wont fit i tried on mine...i think the 4th gen SI should fit on the Z6 intake though...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-14-2003, 07:44 PM
erbinone's Avatar
The D16 fits perfect in the bay. I guess I will have to use a 88-91 Si AF intake. Thanks.
Old 02-17-2003, 10:22 PM
erbinone's Avatar
The 88-91 Civic Si Intake works great! Thanks for all the suggestions!
Old 02-17-2003, 11:36 PM
91civicDXdude's Avatar
im using a 99-00 Si intake and it works fine. I belive that all the intakes are the same.
Old 02-18-2003, 09:30 AM
erbinone's Avatar
Really? Do you have a pic of your intake set up please??
Old 02-18-2003, 09:47 AM
marked001's Avatar
Moderadur
the 99-00 si intake is pretty much gonna be the same as the 92-up...its a little bit bigger diameter I believe...but it still cuts straight through the engine bay...so there's gonna be a problem with the battery unless its moved to the back..
SOLD!
Old 02-18-2003, 11:39 AM
erbinone's Avatar
Are the 88-91 Dx & Si intake Air tube's exactly the same?
Old 02-18-2003, 12:01 PM
marked001's Avatar
Moderadur
yeah..should be exactly the same.
..personally, I'd get teh cheapest intake you can find... hit up ebay
SOLD!
Old 02-18-2003, 03:25 PM
erbinone's Avatar
I got the pipping from my wholesaler for $10 for a short ram, but need stock air tube to pass smog.
