Old 02-14-2003, 12:39 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
JDM projectors
Eventually I want to do the JDM front end conversion to my sedan, but I would also like to have projector headlights. I was wondering if they made projectors that would fit right with the JDM front end, or if the stock JDM lights are brighter than the USDM ones and I should just stick with them after I do the conversion.
I'm Jordan
My car is the ugliest one on this board
Old 02-14-2003, 01:59 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
CRX projectors will fit the sedan fine just by swapping the brackets from your stock over ... personally if you are gonna go jdm, GO jdm, dont try to go too many styles at once.
If you choose to do black projectors consider tinting your corner lenses, I used a translucent spary I got at my local hobby shop ... pics and my method can be found by clicking the link below.
http://www.automotiveforums.com/vbul...=tinted+lenses
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 02-14-2003, 02:13 PM
mightytexn's Avatar
If I do end up getting projectors I want some that look like the JDM stock lights as much as possible.....I just want the projectors so I have brighter headlights.
I'm Jordan
Old 02-14-2003, 02:21 PM
Melt's Avatar
If you want the jdm look with brighter headlights then consider doing the HID conversion, or try out some nokaya (sp) hiperwhites.
WARNING: nokaya's use WAY more power than stock lighting so you MUST upgrade your wiring before use or you will burn up your wire harness.
I remember someone talking about it on superhonda a while back, but I cant find it cause the admin there disabled the search function for some reason
AF Bay Area Crew
Old 02-14-2003, 02:27 PM
mightytexn's Avatar
Where could I get the HID conversion or nokaya from?
I'm Jordan
Old 02-14-2003, 02:32 PM
Melt's Avatar
I dunno, once the search function is reenabled on superhonda I could ask.
AF Bay Area Crew
