exhaust header cover...i need help
ok on my exhaust header cover, the area around one of the bolts totally broke off, now i was wondering, should i go ahead and take off the cover, because at about 1,800rpm it rattles but then goes away at 2,000rpm. but i juss wanted to know if it would be safe to take off the header cover, i was worried about melting wires and stuff around it. but plz help
thnx
S7R33T_R4C3R |
Yeah, rip the sucker off. I had to do that to my wifes 84 because of the same thing. The engine bay will be slightly warmer but shouldnt be that bad. You could also wrap the header if your concerned about heat.
"Nice body kit, looks good in my rear veiw" |
aight coo thnx
S7R33T_R4C3R |
Another downfall will be loss of heat contained in the heads, in essence loss of HP.....
Brian |
There is a temperature point which the engine will run optimal, but heat does not create power, the thermostat controls the heat. So, Brian, if heat creates HP, why should I put a cold air intake on my car? To get cooler air into the engine? Cooler air gives me more HP right? The cover on the headers is a heat shield to protect the rest of the engine, not keep the heat in the engine......
Not personal exp. ...ray....just what I've been told.....
Gripping the wheel, his knuckles went white with desire, the wheels of his mustang exploding on the highway like a slug from a .45, true death. 400 horsepower of maximum performance, piercing the night. This is black sunshine. White Zombie |
You are right, but what Brian said was not....
