Old 02-11-2003, 05:54 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Paint job nicer if painted on a hot day?
Will a paint job come out nicer and smoother if it's painted on a very hot day? Will the paint come out as smoth if I paint it at night?
Old 02-11-2003, 05:58 PM
supratuner's Avatar
im not a pro but i would thank that the paint would not be as gooddo to the humdity, im not sure tho, cause ive sprayed models out side before at 30 F and have had the best paint job ever and thats with testors
Old 02-11-2003, 06:09 PM
daggerlee's Avatar
Ideally, paint would best be sprayed at 70 degrees on a day when humidity is below 50% (which is what all the cans say anyway)
But a paint job is much more dependant on your technique and form, than the temperature of the day.
Beware of high-humidity days however, it can cause some spray paints to cloud over.
Dan
Old 02-11-2003, 06:19 PM
Ghost_9418's Avatar
Ghost_9418 Ghost_9418 is offline
I spray in 30 degree weather.
Ryan
If your new to the AF modeling forum please read this : AF modeling FAQ
Current Project:
Tamiya Porsche Boxster Special Edition
Old 02-11-2003, 06:21 PM
integra818's Avatar
Do you have any pictures of your paintjobs? can you please post them?
Old 02-11-2003, 06:27 PM
supratuner's Avatar
the VR4 in the center, its silver, was sprayed in 30 degraa weather, i thought the paint would freez but it didnt!
Old 02-11-2003, 06:35 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
I spray in 70-90 degress dempending on my weather, i like in Tustin, so the weather changes alot. Well its rainy today down here, but i still get pretty good paint jobs in those weathers.
Old 02-11-2003, 06:56 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
I believe that having it a hotter day, and less humid (day) not night, would be the best for cople reasons
1. hot day = u dont have to warm the can up as much, therefor, the paint is Overall hotter, other then when u put it in water, some spots might be hotter than others...
2. Less humid= less factors that can mess up ur paint job, plus water might, if its humid enough, react with the paint, causing little drips (correct me if im wrong)
Old 02-11-2003, 07:03 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
That's why you shake the can after heating it up in water. Paint under whatever conditions you have, but I recommend painting in a garage or something (be sure to use a respirator). Less dust flies around, and if you have flourescent lighting in your garage you can have better inspections of your paint jobs while you're going along.
Old 02-11-2003, 08:43 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
Heat up the paint
I have found that the hotter the day the smoother the paint seems to be. I figure bodyshops bake the paint on real cars so why won't a hot hot day do the same for a model?? sometimes I even heat up the can under hot water to make it even smoother.My best paint jobs are done on a nice HOT summer day!! here in Charlotte though it is to damn cold to paint right now and it is driving me CRAZY!!! I need to move somewhere tropical!!!
Old 02-11-2003, 09:42 PM
Mainomega Mainomega is offline
I live in Buffalo Grove, a northwest suburb of chicago. It gets extremely cold here, and in the summer extremely humid. I have an extra room that i use as my "hobby room" i set the temperature at 82 degrees during the winter and leave the A/C off in the summer, so i dont have to worry about the temperature. I have a lot of things i have to worry about and i dont want my models comming out bad just because it wasn't a good day to paint.
Got Something Good ? E-mail me
Old 02-11-2003, 09:47 PM
Mean_B16's Avatar
RE:
I wish I were so lucky, I can only paint inside, besides the fumes of the paint has given me health problems before (I used to paint indoors about 10 years ago but not with enough ventilation). Maybe when I get a house instead of an apt. I can have a spray room. ahhhh....that will be sweet.
Old 02-11-2003, 09:50 PM
F-40's Avatar
F-40 F-40 is offline
Send a message via AIM to F-40
I get a high of about 40 where I live , so should I wait till it gets a little warmer before I do any painting? Or would it be fine to keep the can in the house, quickly go outside and spray it, put it in a box of some sort and put it in the house to dry?
Current Project:
Tamiya Toyota Celica GT-R-Only have the body left, Also My First
Portar Ferrari F40-Just Finshed the Engine
Tamiya Nissan 300ZX-Finisng up the engine
Tamiya Porshe 911 Carrera-Finished undercarege
Old 02-11-2003, 10:10 PM
MEKANIK MEKANIK is offline
If you were in a garage you could put up a small halogen lamp next to the car body once you've painted. Halogen bulbs create heat so this could be a good idea, right?? Correct me if I'm stupid.
Old 02-11-2003, 11:18 PM
Would that just bake the top layer of paint? kinda like what happens if you spray clear to quick and it causes the gasses of the paint to be trapped and hence crack
Painting A Tri Coat Paint Job LearnAutoBody Auto Collision Network 0 03-27-2010 05:19 PM
1970 Chevelle Paint job xraab Classic Cars 1 05-24-2009 08:53 PM
On a paint budget? Check out the $50.00 Paint job Rudytadow Mustang Talk 8 10-13-2006 10:32 PM
cool old car paint job hot rod jgilley345 Graphic Manipulation 5 06-05-2005 09:24 AM
What is wrong with my paint job? Ron Ketcham Engineering/ Technical 9 03-25-2001 04:25 PM
