Old 02-11-2003, 04:17 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
Masking windows!
I can't do it! i tried to hand paint them but its not very easy.. and i can't get the tape to work! do u cut the tape, then put it on, then cut it with an exacto? or do u have to have it cut, perfectly b4.. im tryin to do it on my 300ZX and i tried hiroboy's templates and their too SMALL??wat should i do?
Old 02-11-2003, 04:21 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
What kind of masking tape are you using? Tape it by hand with Tamiya masking tape the best you can, and hand brush it with flat black.
Old 02-11-2003, 04:23 PM
Integra14's Avatar
Tamiya 10 mm
Old 02-11-2003, 04:26 PM
hirofkd's Avatar
hirofkd hirofkd is offline
10 cm is too wide. Just use scissors and make two narrow strips of say, 3 mm wide, so that it can follow the curve.
* I mean "mm" Sorry.
Hiroaki Fukuda
Old 02-11-2003, 04:27 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Hey go to the FAQ it tells u all about it.
Old 02-11-2003, 04:42 PM
bah humbug's Avatar
He said 10mm.
Goodness! 10cm, that could cover the whole side of a model.
Old 02-11-2003, 04:45 PM
freakray freakray is offline
AF Modelrater
For once, Shorty actually has a good point
Here is a link to the section you want since you don't use the FAQ:
http://www.automotiveforums.com/vbul...996#post578996
AF User Guidelines
Old 02-11-2003, 04:48 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Re: Masking windows!
They should be fine for a Tamiya 300ZX, maybe your not printing them 1:1
Steve a.k.a. Hiroboy
Old 02-11-2003, 04:49 PM
Integra14's Avatar
I did check that out, and it doesn't help how i should cut the masking.. i guess its just a "test fitting" kinda thing.. i proly will waste a lot of tape!
Old 02-11-2003, 05:05 PM
Hmm.... I hatw masking, so i taught myself to handpaint them. All i can say is learn it. Rest your forarm against a book or something so you have a steady hand. Then just focus on the lines of the windows and paint in them. If you go outside, bust out a wet q-tip and toothpick and "push" the paint off. Thats how i do it.
Old 02-11-2003, 05:50 PM
primera man's Avatar
"P-Man"
Yor need to cut the tape down to 3-4mm so it is easy to curve around and follow the lines you wish to paint.
For small windows like rear quarter etc i use 18mm Tamiya tape and then cut the shape of the window out and make it similar to what they have in the new Tamiya kits (masking seel)
View All My Models Here.
Old 02-11-2003, 06:12 PM
Integra14's Avatar
i startd it again now... im using Acrylic piant, can i dab a q-tip in alcohol (rubbbing) and then use it to get it off, Or water?... should i wait for it to dry
Old 02-11-2003, 06:15 PM
=p
Hey IM me on AIM and ill tell u hwo to do it, MaxSE told me hwo to do it a really good way that is easy to get off if i mess up.
Old 02-11-2003, 09:14 PM
935k3's Avatar
935k3 935k3 is offline
alcohol will take it off with no harm to plastic. whatever you do don't cut the tape on the plastic.
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
window regulator daspyderman LS | MKZ 6 03-09-2009 03:07 PM
93 regal 3 windows work 1 doesnt gmfan88 Regal 0 02-25-2009 01:00 PM
Window regulator troubleshoot anfrhm Sidekick 0 02-19-2009 12:40 AM
How many use BMF to mask window trim? oregon3 Car Modeling 3 09-06-2006 03:23 AM
