Old 02-11-2003, 12:13 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
88 or 91 hatch suspension?
i have an 88 hatch that im building up right now. the car is basically a rolling chassis right now because we are going to start bodywork in a week.
i know that the 88 has some different suspension parts on it from the later years, but i havent pulled it apart yet to see exactly what is different.
i have a 90 hatch that is totalled, but it has a complete suspension swap from a 91 CRX Si. disc brakes and all
heres the question: which parts from the 88 are better than the parts from the 91 CRX Si. i have noticed that the lower control arms are different, but is that all?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-11-2003, 12:18 PM
GTA's Avatar
GTA GTA is offline
Whee..
the lower control arm was th difference...i dont think there was anything else..
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 02-11-2003, 12:37 PM
EF You's Avatar
EF Life Giver
ok, from what it looks like, that means the strut is also different. does anyone know which setup is better?
Old 02-11-2003, 12:40 PM
GTA's Avatar
GTA GTA is offline
Whee..
yes the strut is different cause the difference in lower control arm in the mounting point. With the 89-91 you'll have more choice for shocks such as KYB agx's arent made for the 88 control arms..But the 88 control arm is the same as a Integra Type R, i've heard you can use shocks for the ITR with a lil modifying..
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 02-11-2003, 12:43 PM
EF You's Avatar
EF Life Giver
hmm, well i already have good struts, but if i find enough reasons to use the 88 control arms, i might
Suspension for my truck RoudyRides Engineering/ Technical 5 04-19-2010 06:59 AM
2000 venture suspension noises/woes pjw73nh Venture 27 02-28-2010 08:01 PM
ZR2 suspension 4x4chevymanS10 Performance 10 08-14-2009 11:45 PM
2001 Interceptor version, suspension problems... ratherbestrummin Crown Victoria 0 07-22-2009 06:20 PM
87-91 Camry Rear Suspension Parts F/S nohablaingles Classifieds 0 07-02-2009 10:22 AM
