Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-11-2003, 06:41 AM
wmstwo wmstwo is offline
Programming keyless FOB-2002 S10
I would appreciate any insight on programming a new factory keyless remote for a 2002 Chevrolet S10 ZR2 pickup. Thanks!
Old 02-11-2003, 08:38 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Looks like you will have to take this one to the dealer.
2002 Chevrolet S10 Pickup - 2WD
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs.
Press the START soft key on the scan tool.
Important
The scan tool must stay connected until all of the transmitters are programmed.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the locks will cycle in order to confirm the programming of that transmitter.
Repeat the previous step in order to program up to 4 transmitters.
Remove the scan tool.
Operate the transmitter functions in order to verify correct system operation.
How to program a FOB (keyless entry) for a Pontiac 1998 SE Larryott3 Bonneville 1 08-31-2009 07:09 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
programming keyless fob ardsee '96-'00 Civic 0 07-01-2007 03:37 PM
programming keyless fob Lionel Lee Grand AM 1 03-13-2007 02:11 PM
Any Idea How To Program Keyless Fobs For 1994 Jimmy??help!! jimmy23 Jimmy 2 11-30-2005 05:48 PM
