Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-09-2003, 08:02 PM
mikefxu mikefxu is offline
whats the best camber kit
Iam looking for camber kits. I have found there are 3 types for the front: Pivot Mount, Ball Joint, and Offset Busing.
Example found here:Ebay Link
What would be the best type, price not being a concern.
Thank You
Mike
Old 02-10-2003, 08:50 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I recommend the Skunk2 kit or Progress Group.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 02-10-2003, 01:57 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Maybe it was just a fluke, but I had a friend who had his car recently stolen, and then thankfully recovered (Jaron95 if you remember him on here) and he had Skunk2 front camber kit. Anyways, somewhere in the process of towing and impound, one side of his camber kit busted. The ball joint actually popped OUT of the arm it's attached to causing it to twist and flex when he'd turn his steering wheel. It could have been from the roughness his car went through by the tow company (they didn't put front wheels on his car to move it around since his rims were stolen) so that might have had something to do with it. The ball joint system kinda makes me weary though...
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 02-25-2003, 02:19 AM
SuperGreen95EX SuperGreen95EX is offline
I thought Progress only allows for 1.75 degrees +/-?
Would this be ok for coilovers and how much will 1.75 allow you to lower it?
"It ain't fun if you ain't scared"!
1995 Civic w/GSR swap and stuff......
99 Pontiac Trans Am w/ 4:11's
Old 02-27-2003, 07:09 PM
AlwaysMovin AlwaysMovin is offline
Lightbulb
Not to low, I have Progresses camber and their spring which are suppose to drop the car two inches. Yet even with the camber kit on I still have 1 degree of camber eating up my tires.
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 02-27-2003, 08:15 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
I am lowered 3" on Dropzone coil overs. I have a Progress Auto camber kit that i believe only goes to 1.75 degrees. The guys at the shop said they managed to get my camber back to 1 degree on the front and 2 in the back. I have no problem with tire tread. It made my car higher though, but that's expected when your tires sit more perpindicular to the ground. My camber kit was like 370$ after parts and installation.... good luck
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 03-03-2003, 11:56 AM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
I second the Skunk2 motion. I have a Skunk 2 Camber kit and have yet to see a problem with it.
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 03-03-2003, 12:02 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
i've heard of ingalls busting out. i higly reccomend the anchor bolts/offset bushings. the offset pivot will give you more trouble with the alignament and especially the caster angle. i have the sprint extreme kit
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
