Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-09-2003, 07:36 PM
mad max 98 mad max 98 is offline
Arrow how to convert unleaded fuel car to leaded fuel car
what do u do f u have to put a leaded fuel in ur car , does make any diff.
Old 02-09-2003, 08:42 PM
DiS's Avatar
DiS DiS is offline
Send a message via AIM to DiS
Not a good idea. Leaded fuel contains a metal (its either aluminum or zinc) I think its the second metal but not sure though. Anyways, unleaded fuel does not contain that metal in it, and if you will put leaded fuel in ur car, it will make a hole in your gas tank and burn all your fuel lines that go to the fuel pump. If that happenes your fuel pump will stop working in 2-3 weeks,as of clogging action. DO NOT USE LEADED FUEL.
97 Nissan Maxima GXE
Auto Trans
Red Injen Racing Division CAI with K&N FilterCharger, Zero1Racing Front Strut Bar
DaRk GrEeN/Beiege Interior
Cleared out taillights/Clear fronts/rewired blinkers and sidemarkers, upgraded grounding...Check my Pics out on my homepage
New purchase BRAND NEW '03 Mazda ProtegE 5-spd
_________________________________________________
Maximum Respect To MaxiManiacs and all Nissan 0wn3r$
Old 02-10-2003, 12:54 AM
:bandit: so is there a way to do a conversion?????
f u have any advice let me know.
Old 02-11-2003, 04:51 PM
Strider Negro's Avatar
Strider Negro Strider Negro is offline
Send a message via ICQ to Strider Negro Send a message via MSN to Strider Negro
why would u want to convert your unleaded car to leaded?
Old 02-11-2003, 04:54 PM
JBL85 JBL85 is offline
Send a message via AIM to JBL85
Might not be a good idea considering they dont really sell it at gas pumps in America
Old 02-11-2003, 05:24 PM
where i'm going they dont sell unleaded[okinawa] japan
Old 02-11-2003, 11:52 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
hate to say it, but prob be easier to get another car and leave the max behind
Old 02-12-2003, 03:43 AM
DiS's Avatar
DiS DiS is offline
Since you are going to Japan and since they sell leaded fuel over there Im pretty sure they have cars already converted to LEADED FUEL ONLY. If you would want to make the car to take leaded fuel in USA you would have to redo the whole engine due to leaded fuel is heavier substance than unleaded, because leaded fuel contains metal texture. Even if you do a conversion to your gas tank and leave everything else as is, 1st your fuel pump will break due to clogging up, then if that leaded fuel will get into the engine compartment (AND IT WILL) you will have to probably to buy a brand new engine.
Auto Trans
Old 02-12-2003, 09:31 AM
NJMAXSELTD NJMAXSELTD is offline
There's nothing to convert. Leaded gas was used in older iron head cars to keep the top end, valves seats ect. from burning up. Leaded fuel has more lubrication then unleaede fuel does. Burning unleaded fuel in an older car that was designed to run on leaded fuel is where the problem arises. Fuel additives are used to keep the top end in good shape on older cars. Unleaded fuel should be available across the world. Leaded may be still found in some 3rd world countries.
Burning leaded fuel in an unleaded engine will do no harm to the engine itself, but it will reak havoc on the Cats & o2's.
The fuel itself will not harm anything like your gas tank, fuel pump, injectors or lines.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 02-12-2003, 01:15 PM
Its shit though, why would they even have it in Japan?
Old 02-13-2003, 04:32 AM
DiS's Avatar
DiS DiS is offline
Funny thing. My uncle (dumb@ss) Had a Mercedes in Russia which used unleaded fuel ONLY and his sorry @ass put the freaking leaded fuel, and he burned a hole in his gas tank....
Auto Trans
Old 02-13-2003, 09:34 AM
Impossible - Your uncles tank sprung a leak due to the tank failing.
It had absolutely nothing to do with the fuel in it.
On top of that, you cannot fit the nozzel of a leaded gas pump into a car which runs on unleaded gas, it's to big.
There's no way to get the wrong fuel into it in the first place.
Old 02-13-2003, 12:17 PM
DiS's Avatar
DiS DiS is offline
As I said. My uncle is an idiot :bandit: Dont know how he did it.
Auto Trans
Old 03-08-2003, 08:51 AM
IXLR8TL3.2 IXLR8TL3.2 is offline
Send a message via AIM to IXLR8TL3.2
YUP couldn't have said it better myself, i was hoping someone would realize this
Old 03-08-2003, 10:43 AM
DiS's Avatar
DiS DiS is offline
Auto Trans
