Old 02-09-2003, 12:25 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
testors Enamel
I am going to use testors Flat Black enamel, to do my window frames... I am using tamiya maskin tape,... is this ok? or should i get acrylic?
will enamel leak through tamiya masking tape?
Old 02-09-2003, 12:28 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
I assume you used tamiya paint for the body? In which case, go with enamels since if any paint happens to leak thru the mask, you can rub it out. Acrylics, in my experiences, tend to stain on certain colors.
ales's Avatar
ales ales is offline
Forza Schumacher
Airbrushing or paintbrushing?
Both enamels and acrylics are suitable for airbrushing, but I would recommend using enamels only for paintbrushing.
Old 02-09-2003, 12:52 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Hey use waterbased Acrylic paint, cuz if u use enamel if u make a mistake and try to takeit off it wont come off. Tell me if this works.
Old 02-09-2003, 12:58 PM
ales's Avatar
Forza Schumacher
Shorty, why don't you try brushpainting water-based acrylics and then tell us when it doesn' work! Don't give advice that you don't know will work! (and I know from personal experience that it is likely not to work).
Old 02-09-2003, 01:26 PM
=p
Hey in know its works cuz MaxSE told me it does, thats how he did his Panel lines on his EG Civic.
Old 02-09-2003, 01:55 PM
ales's Avatar
Forza Schumacher
Good for you! Now, what do panel lines have to do with this thread?
Old 02-09-2003, 02:27 PM
tonioseven's Avatar
Old 02-09-2003, 02:30 PM
clatescivicr clatescivicr is offline
Re: testors Enamel
Hey, I didn't use Tamiya masking tape, but I used Testors flat black enamel and it didn't leak through the tape. Also if you do get it on the actual window area you can take a toothpick and lightly "scratch" it off without effecting the "glass."
Clate - I'm back
Old 02-09-2003, 02:48 PM
Integra14's Avatar
alright thanks GREAT! i just bought some!!! im goin to try it right now!
