Old 02-09-2003, 08:58 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
wtf is a mini-me??
ok now i know i am a noob but wtf is a mini-me setup??
Old 02-09-2003, 09:14 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
I belive it is a SOHC VTEC in an 88-91 CIVIC.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 02-09-2003, 10:12 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Its a set up that goes like this...
a non v-tec block with a sohc v-tec head. Basically its like an ls v-tec .
Its a pointless set up. I would just go full sohc v-tec swap.
Old 02-09-2003, 11:15 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
My thoughts exactly!!!! I hear they dont even run right, i believe its so much better and worth it by getting the whole z6 or y8
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 02-09-2003, 12:45 PM
91civicDXdude's Avatar
an actual mini-me consists of a d16z6/d16y8 head on a d16a6 block. In all actuality, the d15 block with a vtec head has a lot of potential, due to the fact that d15b2 has flat top pistons, so a vtec head on that block has higher compression than the stock d15 plus the addition of vtec.
If you're looking to go cheap, then a mini-me is a good setup since you get can a sohc vtec head for about 100 dollars, versus a couple hundred for the whole engine. If you have the funds to spend, then yes, getting the entire engine is a good idea.
Old 02-09-2003, 12:51 PM
mellowboy's Avatar
Its not cheap. All those parts you have to get to complete the set up cost nearly 700 to 1000.
Old 02-09-2003, 01:05 PM
I dont know where you're shopping, but you are getting ripped off big time.
VTEC head - $100
rpm activated switch - $80
head gasket - $25
TOTAL: $205
this is if you are doing a real mini-me. since a proper mini-me consists of a d16a6 block, you dont have to swap to mpfi. If "mini-me-ing" a d15b2, it will cost you maybe an extra 200 for the mpfi parts.
Old 02-09-2003, 01:07 PM
mellowboy's Avatar
VTEC head - $100
head gasket - $25
TOTAL: $205
YOu need more than that.
Old 02-09-2003, 01:09 PM
uh, negative.
unless you want to swap over to OBD1, and then you'll need an extra $150 for the harness and an extra $100 for the ECU.
Old 02-09-2003, 01:29 PM
mellowboy's Avatar
uh, negative.
Z6 head from a 92-95 Civic Si/Ex
Head gasket, intake gasket, and exaust gasket from 92-95 Civic Si/Ex
Timing belt from 92-95 Civic Si/Ex
Valve cover gasket for a 92-95 Civic Si/Ex
RPM Activated switch, or Vtec controller (such as Fields, or APEXi)
Adjustable Fuel Pressure Regulator, or FPR from 92-95 Civic Si/Ex
I would use the ecu from the 5th gen ex/si.
T
Old 02-09-2003, 01:31 PM
so you're saying that a couple gaskets and belts add up to 700-1000 dollars?
Old 02-09-2003, 01:33 PM
mellowboy's Avatar
well i was mistaken. I was looking for oil pump and manifold also.
Old 02-09-2003, 01:36 PM
just to clear up some things, in my experience, i've found that if you are going to keep your stock non-OBD ecu, then it is wise to keep your Si intake manifold and sensors rather than using the d16z6 intake manifold. with the z6 mani, you'll have to reroute some vacuum lines and other small miscellaneous things. IMO, if starting off with a d16a6, it is easiest/most cost effective to just swap the head. btw, intake manifold/exhaust manifold gaskets are very often reusable.
Old 02-09-2003, 03:38 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Hey, we just did one at work on sat. in a 94 hb with a d15b7 block we put a 97 SOHC vec head. Car ran, didn't hook up vtec though. No problems as of yet.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
