Old 02-08-2003, 11:41 PM
strodda strodda is offline
hp on a 96
friend of mine has a stock 96 v6, anyone know what the hp/tq is?
Old 02-09-2003, 05:47 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
It makes 150 hp and something like 212 tq
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 02-10-2003, 06:59 AM
dirk-diggler's Avatar
dirk-diggler dirk-diggler is offline
Banned
150 hp??!! from a huge 3.8L??!!
Old 02-10-2003, 01:54 PM
94svt5.0's Avatar
Pretty sad eh? In all of fords wisdom they figured the V6 drivers would not want to go fast. Its a big v6, buts it an old school, low revving pushrod engine, thats limited by weak heads and cam. The 94-95 v6 mustangs made 145hp. The 96-98 made 150 and the 99 and newer make 190 hp. The 2005 mustang, is supposed to drop the 3.8 in favor of a 3.0 making maybe around 210 hp.
1994 Cobra
-off road h-pipe
- stock
-K&N
Old 06-19-2003, 08:40 PM
skubee-raw's Avatar
skubee-raw skubee-raw is offline
Send a message via AIM to skubee-raw Send a message via Yahoo to skubee-raw
yeah, and since the car is heavy, that motor sux. that's why if you want power/speed, there's the gt, the cobra, the saleens, the steedas, the kenny browns, the kenne bells, the roushes, ect.
Old 06-22-2003, 05:46 PM
YJGWRacing YJGWRacing is offline
Send a message via AIM to YJGWRacing Send a message via Yahoo to YJGWRacing
the 3.8's in no way suck, stock, they are weak, but modded, make nice motors.
i have a Factory Supercharged 3.8 (Eaton M90 @ 10psi) in my 91 Thunderbird Supercoupe, and the motor makes fine power for stock. With simple mods, i will easily be making 300+bhp.
Procharger is getting low 13's from a 99+ auto v6 stang with just 3.73 gears, exhaust, drag radials, and a 11psi Tuner kit.
Oh yeah, and theres a guy in Canada with a 4.2l stroker with 99+ 3.8 heads, 90 SC block, Cam, 1.73RR's, intake, fuel, etc., and should be making around 260+rwhp/300+rwtq on motor, and its setup to handle a 200shot with no problems. Can you say 500rwhp/550+rwtq from a v6 stang?
Old 06-24-2003, 06:56 PM
fordmustang23 fordmustang23 is offline
don't dis the 3.8 The 3.8 is about the longest lasting v6 you can buy. I'm going to be sixteen in a year and i'll be buying a mustang v6 because i can't afford the insurance on a camaro or v8 mustang. American cars have great hp but the extremely high insurance is the reason that dumba$$ kids buy ricers.
ricers are like tampons, every pussy has one.
Old 06-24-2003, 08:32 PM
Unit 5302 Unit 5302 is offline
Send a message via AIM to Unit 5302
I'll tell you right now he's overly optimistic about those numbers. The 4.2L is sitting at 210hp stock, to add 90hp N/A is a huge gain. The 4.6L would certainly never see it on a streetable combination. It'll take serious port work, higher compression, a significant cam, and a majorly ported or aftermarket intake system. I would be more inclined to believe 260-280hp from the engine 220rwhp-235rwhp. Furthermore, you can NEVER expect a 200 shot to make 200hp on a properly tuned engine. If you're tuning safe, like you should be, 175hp is the most I'd like to see from it. So I think in the real world, he'll be talking more like 450hp at the crank or about 375rwhp, which would be about the same amount of power the 5.0 in a fox would make with an ATI Procharger and a port job.
Throw in the fact he needs to change the transmission/rear end to get it to hold together and you've got a very expensive combo he's creating. I don't anticipate he'll have too many problems with bone stock newer GT's or even the old SD fox 5.0s, as soon as he runs into a light modded 5.0, he'll have his hands full unless he sprays. Sad but true. Also he should be running a forged crank/rods/pistons setup on that combination if he expects it to hold together.
All that money for what? Will the car be cool? Yep. Is it something to brag about in terms of the engine's capability? I don't think so. Anything can be made fast with enough money, and the $1000s he's spending to get the power he's expecting
2002 Mustang GT Coupe
1993 Yamaha FZR 600
Old 06-24-2003, 11:26 PM
Los Los is offline
Send a message via AIM to Los Send a message via MSN to Los
90 hp on a 4.6 isn't too hard...
Just stage III heads and a wild cam...
Of course, pulleys, SVO/Bullitt intake, mass air, the usual boltons would help too.
Los
Texas Racing Scene.com
Lawton Racing
