Go Back   Automotive Forums Car Chat > Alfa Romeo > 156
Old 02-07-2003, 03:05 AM
AlfaRomeo156's Avatar
AlfaRomeo156 AlfaRomeo156 is offline
Unhappy Stereo Overheating...
Does anyone have a problem with non-stock stereo's overheating? My Kenwood has a large heatsink on the back which sits tight up against the plastic at the back of the dash, its behind this plastic that the hot air for the windscreen de-mister runs, when it's on it quickly heats the stereo and it becomes distorted and drops the volume etc....
anyone else had similar problems, and anyone got a remedy?
Cheers.
Old 02-07-2003, 03:58 AM
Jimster's Avatar
Jimster Jimster is offline
Here for the pussy, man.
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
Re: Stereo Overheating...
Cheers.
I think you should check the wiring- have a look through it- If you still can't see a problem come back here
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Old 02-07-2003, 04:01 AM
The wiring is all A ok.
I made sure the wire's were not squished behind the stereo as I installed it... I only get the problem when the heater is on.. I checked the other day, I pulled the stereo out and put my hand on the back plastic plate and it was hot... The only thing I can think of is to get a hold of some heat reflector, like the stuff you put on your bumper.. would this work? Otherwise I could relay in an old 80 mm computer fan to blow cold air accross the heatsink..!
Old 02-08-2003, 03:37 AM
Jimster's Avatar
My custom headunit never gave me this sort of problem..................I think that heat reflector could be a cheap way around it- worth a try indeed
Old 12-04-2003, 09:23 AM
jwchoi jwchoi is offline
CD Player Overheating
I also have a non-standard CD player (Sony) in a 1.8 TS.
After around 1 hour of constant playing, the CD player will not be able to read the CDs (error message apperars). The ejected CD is very hot to the touch. I will have to wait at least 30 minutes before I could play CD's again.
This problem was not apparent during the Summer, but only now that I am using the heater. Any ideas?
Also, why doesn't the CD player switches itself off when I turn the ignition off? The lights go off. The CD should as well. Any ways of doing this?
Thanks.
Old 12-05-2003, 06:42 AM
franzzz franzzz is offline
Re: CD Player Overheating
Thanks.
I have an Pioneer DEH-9000 and dont have a overheating problems in this season.
but in the summer the CD is very very hot after 1 hour of music....
The high power of the new generations of car audio (45x4,50x4 and 60x4 mosfet) is the real problem....
