Old 02-06-2003, 01:11 PM
DArkforces9 DArkforces9 is offline
Send a message via ICQ to DArkforces9
B18a ?
I cant find this anywere on the web. How much HP does the B18a have?
Old 02-06-2003, 01:14 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
im guessing around the same amount as the b18b
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-06-2003, 01:16 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
130hp@6000rpm 121 ft/lbs@5000rpm 9.2:1 c/r
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
So it wouldnt be worth it to go with the b18b right.
Old 02-06-2003, 01:18 PM
b18b has like 145 hp, you would probably be alittle happier with the b18b
1991 Honda Crx Si
Old 02-06-2003, 01:19 PM
BLU CIVIC's Avatar
調整器
• DOHC 4 Cylinder 16 Valve
• Hydraulic Transmission
• Displacement: 1834cc
• Torque: 127 lb-ft@5200
• Horse Power: 142hp@6300
• Compression Ratio: 9.2:1
The name's Adrian
2011 CR-Z - Stock
Old 02-06-2003, 01:22 PM
is there enough space left over to put a turbo on? or do you have to move stuff?
Old 02-06-2003, 01:23 PM
BLU CIVIC's Avatar
調整器
ENOUGH SPACE BUT YOU MIGHT WANT TO RELOCATE UR BATTERY TO THE TRUNK....WHAT ARE U TRYING TO DO?
The name's Adrian
2011 CR-Z - Stock
Old 02-06-2003, 01:26 PM
i was thinking of getting a b18b and putting a turbo on it. I dont want to run like 12lbs boost only like 6-8lbs.
Old 02-06-2003, 01:27 PM
BLU CIVIC's Avatar
調整器
WHAT ARE YOU TRYING TO GOAL ACHIEVE OR ARE YOU WANTING TO SPRUCE UP YOUR STD??
The name's Adrian
2011 CR-Z - Stock
Old 02-06-2003, 01:29 PM
that was the idea. should i just dump th std and get an si?
Old 02-06-2003, 01:31 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I would get an Si and go from there.
Old 02-06-2003, 01:34 PM
BLU CIVIC's Avatar
調整器
YOU CAN DUMP YOUR STD AND GET AN SI OR JUST CONVERT IT TO AN SI.....ME PERSONALLY I'M SWAPPING MY STD FOR A DOHC ZC AND ADDING A TURBO....
http://www.automotiveforums.com/vbul...threadid=85429
The name's Adrian
2011 CR-Z - Stock
Old 02-06-2003, 01:38 PM
Thanks for the help
Old 02-06-2003, 01:40 PM
BLU CIVIC's Avatar
調整器
NO PROB
The name's Adrian
2011 CR-Z - Stock
