Old 02-05-2003, 11:08 PM
Toksin's Avatar
Toksin Toksin is offline
Non-profit Organisation
Send a message via AIM to Toksin
Need some help techies (Toyota Supra)
Well, the Evo is nearing completion, so I've started thinking about the Supra, and I need to know where I can get info as to where the alternator, distributor etc go, I ordered white metal parts for a little extra detail this morning, but I can't find any good sites which actually show me a nice layout of the engine
:help:
Old 02-06-2003, 12:40 AM
magicmanjk808 magicmanjk808 is offline
Send a message via AIM to magicmanjk808
uksupraboy had some awesome sites in a thread a while back, i'll try find them, or you could do a search.
Current Project:
Fujimi Toyota Altezza RS200
bye bye handles, moldings, rain gutters, license plate holders
View some pics of it here http://www.automotiveforums.com/vbulletin/t72123.html
Old 02-06-2003, 12:47 AM
i found them, here you go
http://www.mkiv.com/main/index.html
http://www.ozsupra.qld.org/w......ctures_markiv.htm
i haven't really looked at the second site as i have found all the engine pics i needed in the first site. hope this helps.
Current Project:
Old 02-06-2003, 12:48 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Modified
Standard setup
Steve a.k.a. Hiroboy
Old 02-06-2003, 03:28 AM
hirofkd's Avatar
hirofkd hirofkd is offline
The alternator is located at the lower right side (the turbo charger side), and it's so visible from the top. And I believe it has the direct ignition, and doesn't have one of those conventional distributors, which leads to the spark plugs.
Hiroaki Fukuda
Old 02-06-2003, 06:27 AM
Vric's Avatar
Vric Vric is offline
if you want some hardcore engin
Old 02-06-2003, 02:53 PM
Toksin's Avatar
I've got about 30 pics like that, I'm looking for 360 degree views of the engine...but thanks Hiro for the information about the alternator Hmmm...now I don't need the distributor..hmm...oh well might come in handy at some point
Old 02-06-2003, 04:24 PM
hirofkd's Avatar
http://www.mkiv.com/techarticles/parts/reg_engine/
In those pictures, the alternators were removed, but it sits just in front of the engine mount, and under the water pump.
Try some google image search by "2jz"
Hiroaki Fukuda
Old 02-08-2003, 02:46 PM
heres a pic from mkiv.com
Current Project:
Old 02-08-2003, 04:47 PM
Toksin's Avatar
Now I just need to figure out which one's the starter motor
Old 02-08-2003, 04:56 PM
hirofkd's Avatar
A starter motor is not driven by the belt, but it's attached to the side of the engine and transmission case.
Hiroaki Fukuda
Old 02-08-2003, 05:01 PM
Toksin's Avatar
I'm aware of that
I just need to where it is attached
Old 02-08-2003, 10:39 PM
bvia's Avatar
bvia bvia is offline
Talking
It's bolted to the flywheel/flexplate bellhousing on the transmission/transaxle. It usually bolts into the bellhousing, with the gear sticking into the bellhousing and mates to either the flywheel (manual) or flexplate (automatic). The "can" of the starter motor portion extends either forward (towards the back of the radiator) or towards the front of the engine (in a transverse mounting). From the looks of the above picture, the starter motor is on the right hand side (standing in front of engine, or opposite side of turbo) since the turbo wastegate is residing in the location the starter would, if it were on the "left hand" side.
hth,
Bill
:bandit:
