Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-10-2001, 08:43 AM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
Lighting Harness For P10
My wire are all meesed up. I have to wiggle the wires in the morningto get the lights to stay on. I am sure my FAKE HID's melted them.
Where can I get a new set FAST ?!?!??!?!!
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 10-11-2001, 12:11 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
go to pep boys or discount and buy 2 new headlamp plugs.
just cut yours off and put the new ones on!
Old 10-11-2001, 12:29 PM
Thanks for the reply.
So If I use these that Ijust bought how do i line up the correct wires ?
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-11-2001, 01:12 PM
these right here .....
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-11-2001, 02:34 PM
try to line up both plugs and see where the wires go.
Old 10-11-2001, 07:34 PM
I changed on light but it is much duller than the other one. I switched bulbs to be sure it was not the bulbs.
Did I get a bad brand of harness ?
Maybe I left too much wire and that is causing to much resistance ?
Anyone who has doone this with success please help ....
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-11-2001, 07:38 PM
For those who like me did not believe the harness could really melt ....behold
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-11-2001, 10:37 PM
I just went to the car again switched almost everything around and the passenger side is stll much brighter.
I added the waring harness to passenger sid with wire really cut short. SUPER BRIGHT !!!
Cut down the wire on the Driver's side ..... dulll,,
It's like HID on one side and old ass flashlight on the other ....
The only thing I did not switch is the actually two new harnesses .. I will buy a new harness tomorrow and see if that is the problem ....
PS I melted harness will also melt the prongs on the actuall bulb ....
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-11-2001, 10:56 PM
did you replace both headlight harness or just one?
you cannot use nothin higer than 55 watt or they'll melt!
did both harness melt or just one?
Old 10-12-2001, 09:50 AM
I replaced both harnesses. I am using 55watt light
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-12-2001, 05:59 PM
It turns out the " NEW " Driver side harness was bad ... I replaced it ( $3.50 ) and all good now .....
Thanks for the help ......
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 10-14-2001, 02:18 PM
Wink
no problem....
your welcome!
