Old 02-05-2003, 04:48 PM
strodda strodda is offline
fixing punctured tire
one of those big hardware staples got into my tire on the edge between the sidewall and the tread. im assuming its possible to fix, but would it be a permanent fix or is that just a temp thing and i should still buy a new tire asap. this tire has at least half its tread left, so i dont want to throw it out just because of that.
Old 02-05-2003, 05:49 PM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
chances are a chemical sealer could fix it, but you are better off just going to your local Discount Tire, NTB, etc and getting the tire removed the brad/staple pulled, the hole/s patched, and getting it remounted and balanced. Even if you aren't using a road hazard warranty, it shouldn't be more than about $30 and it will be safe.
jm2c
...or you could just plug it... the kits are only a few bucks.
Old 02-07-2003, 03:03 PM
LoKoBoYraSeR LoKoBoYraSeR is offline
Send a message via AIM to LoKoBoYraSeR
just go to a local gas station that has service, they'll plug it for 10 dollars
Punctured Tire. Polygon Non Specific 6 11-17-2007 01:28 AM
Selling car, how to fix rear tire rub... Thrill91Si '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-23-2004 03:30 PM
