Old 12-22-2007, 06:46 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
GM Dex-Cool Intake Manifold Gasket Lawsuit Tentative Class Settlement.
It's odd that this tentative settlement doesn't include the L67. However, it does mention the L36 & others....Click, or copy and paste the link below.
http://www.girardgibbs.com/dexcool.html
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 12-23-2007, 10:05 PM
bricker82's Avatar
bricker82 bricker82 is offline
Re: GM Dex-Cool Intake Manifold Gasket Lawsuit Tentative Class Settlement.
Thx for the info! My wife's a delivery driver and her 00 GP SE 3.1L V6 had the lower intake manifold issue. She needed the car for her job, so I ended up footing a lot of money to get it fixed in a day. Hopefully, I may be elgible for some type of compensation.
04 GTP CompG 3.8L Supercharged
K&N FIPK/180Tstat/SSC Springs/GMPP STB's/Autolite APP605's/Aluminum Grilles/SPO Tips/17" AE Alloys 185's/2 RockfordFosgate He4410 Subs & 1 P4002 Amp
Old 12-24-2007, 12:11 AM
BNaylor's Avatar
BNaylor BNaylor is offline
What I find odd is that the alleged tentative settlement doesn't include all GM cars that use Dex-cool. Doesn't make sense to me.
It wasn't just the L36 SII 3800, 3.1, 3.4 and 4.3 equipped GM cars/trucks.
Timeslip 08/12/06
AF Community Guidelines
Old 12-24-2007, 11:16 AM
bricker82's Avatar
I don't know the specifics, but is it possible that the gasket was made of a different material that was degradable by DEX cool in those certain engine models? That's the only reason I would think they would do that.
Old 12-24-2007, 01:35 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I cautiously await to see what type of settlement is reached. I'm not a big fan of class action suits, having been party to many through the years. Most of the money that is awarded the plaintiffs is gobbled up in lawyer's fees and the rest is spread amongst all who are party to the lawsuit. The more people involved equals a smaller award per person. It may not be enough to cover the out of pocket expenses incurred by most, but I guess we'll see when it's over.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 12-25-2007, 12:48 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
maybe GM is using "DEX-COOL" as a scapegoat for poor gasket material and and poor torgue procedures.
I know that when my lower intake blew on my lumina with the 3100, upon disassembly, I checked for a split in the rubber around the coolant passwageways. nothing was found. I believe the leak was caused by a bad torque and coolant was just allowed to seep out between the gasket and the heads/LIM.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-26-2007, 06:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Bob, since all GM cars have used Dex-cool since 96. If the coolant was the issue, all vehicles would be included. Also, the GM 96-03 5.0 and 5.7 V-8's were subject to intake gasket failure as well as the engines in Bob's list. IMO, none were caused by Dex-cool, it's the shoddy gaskets GM used (and no longer uses). The most common failure is due to a lateral shift of the manifold that cracks the plastic frame of the OEM gasket. I agree with tblake that since Dex-cool is a GM only coolant, the lawyers are going after it as the cause because GM has more money than it's gasket supplier does. Finally, all of these engines have an improved design metal framed gasket available. If it were Dex-Cool, they'd all have a service bulletin suggesting changing the dex-cool out for some other form of coolant/antifreeze when doing the gasket job.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-26-2007, 07:02 AM
I've never had a problem with Dex-Cool in my 97 GT. I had to swap out my UIM gasket however I really don't believe Dex-Cool was the culprit. I certainly DO NOT wait five years or 150,000 miles to flush the coolant system. IMOP every three years or less is good, safe "and cheap" maintenance.
4 door sedan
No Mods
Old 12-26-2007, 08:16 AM
TbLake, we experienced the same as you with my UIM, we had a bad torque,allowing seepage,in fact we could loosen three screws by hand. Upon further investigating we changed out the gasket, had to anyways.
4 door sedan
No Mods
Old 12-27-2007, 12:54 AM
tblake's Avatar
In God We Trust
yes, once your that far down, might as wll finish the job.
