Old 02-04-2003, 08:46 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
Primer...its not that necessary!!
Ive been experementing with differnt parts. I primed one wing, and then painted. Bah orange peal, even tho i sanded it. Than i just painted the same wing (i have two of them) and everything was clean indeed, and reflections where there, not like with primer. So the conclusion is, you can basicaly save those 5 bucks on that primer and buy another can of spray paint. I dunno what do you guys think?
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 02-04-2003, 08:53 PM
Vric's Avatar
Vric Vric is offline
I used primer on only 3 of my kit out of 22..... I only use it when I need to change color (ie black plastic need to be yellow...)
Old 02-04-2003, 09:11 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Really up to your own opinion/experience. I like using primer as a safeguard for when a paintjob goes bad and I need to strip the paint. Primer helps to keep the paint from staining the plastic body. I've done a lot of kits without primer and they seem to have more sheen, but I've found that using primer gives the paintjob a more realistic appearance.
Old 02-04-2003, 09:19 PM
djmr2's Avatar
djmr2 djmr2 is offline
i've been trying to tell people this all along..
priming isn't necessary to get a NICE paint job.
but the only responses i ever get are
-oh i used to not use primer and my models sucked, now that i do, they're better.
-pman uses it and his models are great
-it says so in the FAQ.
sure there are great advantages to using primer, barrier coat between hot paints and plastics, filling in scratches, to give a single more neutral color to paint over... etc...
but PRIMER will not give crappy modellers beautiful paintjobs..
and if someone can prove that primer chemically alters paint, then please prove it to me so i don't waste my time spreading false FACTS
Old 02-04-2003, 09:41 PM
.porkchop.'s Avatar
.porkchop. .porkchop. is offline
Send a message via ICQ to .porkchop.
i agree..i only used primer on cars that had mismatched colour body panels..ie the SAS S2000, and 350Z
Old 02-04-2003, 10:43 PM
freelunch's Avatar
freelunch freelunch is offline
I gotta primer my kits because I airbrush acrylics to paint...and acrylic paints NEED primer.
Old 02-04-2003, 10:44 PM
tonioseven's Avatar
To each his/her own! It's not really a big enough of an issue to argue over! Do what works best for you:bandit:
Old 02-04-2003, 10:48 PM
Vyacheslav's Avatar
Ok. But i went with 3-4 coats of primer, and it gave a disgusting peal on the body, which procceded to the paint. And sanding didnt help to get the peal away from the primer. Or one coat of primer is enough?
JGTC Mobil 1 NSX
Porsche 911 gt2
Old 02-04-2003, 10:50 PM
MEKANIK MEKANIK is offline
But when you sand the moulding lines the primer fills up the scratches.
Does that mean if you sand and don't use primer then you will see the marks where you sanded on the finished paint job??
Old 02-04-2003, 11:35 PM
crab's Avatar
crab crab is offline
That's very true... primer does fill small scratches from putty work and sanding and such.
As a general rule, primer is used mainly for:
1) detecting surface imperfections
2) filling scratches
3) body color uniformity
4) paint adhesion
So, if you're a beginner or intermediate modeler and you don't care much about the above four items then using primer is merely a preference rather than a necessity!
Referring to pictures of *his* 996 Carrera 4...
"Why would I want to post it in the 996 section if its a 911 that I have[own]??? :huh: :huh: :huh:..."
- sizzilinS7
Boy: I pry apart that battleship you call your ass.
Boy: I see shit nuggets hanging from the hair around your asshole.
Girl: WTF?!?!?
Boy: They stink really bad.
Girl: OMG STOP!!!
Boy: I start to get fed up with your ugly ass
Old 02-05-2003, 12:14 AM
5ynergyx's Avatar
5ynergyx 5ynergyx is offline
hmm... i never use primmer before and don't know what it looks like... but i'm doing my first putty on my S15.. hope it works well for me ~:sun:
Old 02-05-2003, 02:59 AM
primera man's Avatar
"P-Man"
DITTO
This has raged on and on here for ages, so if you think you dont need it, dont use it then
View All My Models Here.
Old 02-05-2003, 05:58 AM
phase5's Avatar
phase5 phase5 is offline
depends on what type of acrylics you use i use tamiya and never used primer and paint are great. i only use primer when ive chopped and filled so i can see any blemishes
glue glue and more glue
www.djamos69.com
Old 02-05-2003, 06:07 AM
tc3house's Avatar
tc3house tc3house is offline
Send a message via AIM to tc3house
this is just a thought, but if you guys are using primer to give the body a neutral colour then why dont you just give the body a light coat of white paint. this way you dont have to worry about orange peal.
personally i dont like primer, i've painted two models using P-Man's guide, one with prime and one with out. the one with out primer looked a lot better than the one with primer. look at my sig i didnt use primer on the R-34 and i did use it on the ITR
Old 02-05-2003, 06:27 AM
SirWelshy's Avatar
SirWelshy SirWelshy is offline
uses autoshop primer or GW undercoat but it depends on what colour i'm putting on to which one i use, i always uses the GW undercoat on the engines as its matt finish, but i have found that since i started using primer the coats do look better, used to hand brush the paints on straight from the tins they came in,
todo -->> Dan Finks speedwagon, taurus, lotus 107, `60 chevy hardtop, austin martin db6, austin healey 100-six, datsun 610? and bmw
http://www.pearce.50megs.com/model.htm
