Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-04-2003, 08:03 PM
pollochicken pollochicken is offline
Question 96 Maxima SE 0-60 MPH timing
I have a problem, I think, with my Maxima. Whats the 0-60 MPH timing its supposed to have if its 1996 Maxima Se Automatic with 17 inch wheels??? I think my car is not performing as well as it should. (It also has a performance K&N Intake and a straight pipe instead of the catalytic converter).
Old 02-04-2003, 09:42 PM
FarbsMaxima FarbsMaxima is offline
Send a message via AIM to FarbsMaxima
for stock 1995 se its 6.6 seconds 0-60, I assume around the same for you if not a little faster cause of the test pipe
Old 02-05-2003, 01:51 AM
thrasher thrasher is offline
6.6 for 5 speed, and that's a car mag test number...if you brake torque it, you should be able to get to 60 a little under 7.5 seconds. btw, 17's didn't come on maxima's until 5th gen
Old 02-05-2003, 05:18 AM
mad max 98 mad max 98 is offline
whats ur timing anyways polloooo
Old 02-05-2003, 09:54 AM
Paonessa Paonessa is offline
me and my friend timed my 95 5 (speed) at 6.2 and i have a cat so you should be a little lower than me. and it was summer so it was like 85 degrees out. don't go by car-mag #'s
Old 02-05-2003, 04:30 PM
Thumbs down
I thought so... My car is very unfortunately doing from 8.51 to 9.76 from 0-60 MPH. What could be wrong with my car??????????/ Someone help!!!!!!
Old 02-05-2003, 04:33 PM
my 17 inch wheels are not from stock, They're aftermarket wheels.
Old 02-05-2003, 04:48 PM
Pick Pick is offline
It may be your straight pipe. They are loud, unreliable, and just straight-up unnecesarry. It may be leaking air, or may not be installed correctly.
Old 02-05-2003, 05:07 PM
Hammer Head Hammer Head is offline
next time u time yourself shift 1an2 manualy becouse if u dont it wont go to the red line and remember to shut off your overdrive this will probably help your time a bit.
Old 02-05-2003, 06:37 PM
I checked the straight pipe. Its not leaking any air and the noise is almost unoticeable. And I also timed it running 1st and second manually with the overdrive off. Any other ideas??????????
