Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-04-2003, 07:55 PM
Hammer Head Hammer Head is offline
Question 98 max stalling
hey hows it going ive got a 98 se it stalls only when it is cold,it starts up and then stalls right away it will keep doing this until i give it a little gas and then it runs normal this only happens when i start it first thing in the morning either than that its fine. Does anyone know what my problem might be its automagic with 91000kms thanks
Old 02-05-2003, 06:41 AM
mad max 98 mad max 98 is offline
i dont think its the trans. but it might be the coolant temp. sensor, it has somthing to do with temp. from what u said, where u from btw
Old 02-05-2003, 10:12 AM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
u use an engine block heater? that may help a lil bit
Old 02-05-2003, 04:52 PM
stalling
today i tuned it up and cleaned out my throtlebody ill let u know what happens in the morning.
Old 02-05-2003, 05:17 PM
stalling
no i dont use a block heater, does anyone know were my coolant temp sensor is located. thanks
Old 02-06-2003, 09:18 AM
NJMAXSELTD NJMAXSELTD is offline
Follow the upper radiator hose twards the engine. It goes into the thermostat housing. There are 2 sensors on there. The first one closest to the hose is for the gauge inside the car. The second sensor closer to the block is the ECTS. Make sure the electrical connections are clean and tight.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 02-06-2003, 04:27 PM
IVE SOLVED IT!!!!
well yesterday i threw in new plugs ,cleaned out my tb, and greased up all the electrical connections going into my tb, and coils with electrical grease and guess what it worked she starts right up first turn and is running stronger than ever! I also reseted my ecu after i was done doing everything. thanks:flash:
Old 02-06-2003, 10:58 PM
Caracicatriz's Avatar
Caracicatriz Caracicatriz is offline
I have the same Problem with my 98 Maxima. When I start it up in the mornings it usually stalls especially when it is cold out. I don't have much of a problem in the summer.
Old 02-17-2003, 12:35 PM
Striker678 Striker678 is offline
Send a message via AIM to Striker678
98' max owner's solution
Hey I had the same problem and I live in MA and it's like 3degrees out right now and my car had been doing the same thing in the morning for cold starts. So I had my fuel filter replaced and now it starts up perfectly. The tech at nissan said that its a common thing if you let your tank run down low cause then it's using fuel thats been in your tank for awhile and isn't really pure i guess and it clogs your filter.
Striker678
