Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-09-2001, 05:13 PM
PRIMERA_BOY PRIMERA_BOY is offline
Send a message via Yahoo to PRIMERA_BOY
Unhappy Intermittent power loss- HELP!
Hello people,
Newbie here... I have a P10... but I went to the p10 area and it said come here....
I wonder if you can help- my mechanics have failed!
Every so often, when driving along, my car starts to judder... as if its running on three plugs or something.... during this time I cannot accelerate. (It happened this evening.....I pressed the accelerator to the floor- no response). It doesnt last long... only 30-60 seconds at most before it fixes itself and the car runs fine again!
I have replaced HT lead, plugs, petrol filter, distributor cap.
The nissan diagnostic machine shows no errors.
It can be 10 miles or 400 miles between this happening. I have been travelling at different speeds and in different outside temperatures.
Any help would be greatly appreciated... I'm lost ...
Old 10-09-2001, 06:02 PM
G20-KIWI G20-KIWI is offline
Sounds pretty bad, have you checked all the vacuum hoses for leaks and intake tubing?
I think even the brake booster vacuum hoses being disconnected can make the car stall
so check everything is tight.
Does it backfire also? Cos it could be injectors, TPS adjustment or maybe AAC valve.
Have the coil checked as well.
-=G20-KIWI=-
Old 10-09-2001, 09:20 PM
greekman's Avatar
greekman greekman is offline
sounds like you may be having the same problems i had on my 93.5 G. check out my thread called sssslllloooowww start (something along those lines, maybe more s's or l's). or check out http://www.se-r.net/engine/troublesh...ide/index.html they have good stuff there and i figured out my problem. you can search the www.se-r.net archieves for additional information, if you don't find your problem here.
93.5 G20
Life is like a shit sandwich. The more bread you have, the less shit you taste. So go out and get your bread!
Old 10-09-2001, 09:29 PM
olds88's Avatar
olds88 olds88 is offline
sounds like a possible fuel pump
what is the world coming to???
Old 10-10-2001, 01:56 AM
CHeers!
thanks guys... i'll check those out!
David.
Old 10-10-2001, 01:59 AM
answers....
hi- forgot to give answers ! D'oh
The engine doesnt stall... just "struggles for a while.... no backfireing.
Cheers,
David.
Old 10-10-2001, 02:00 AM
primera man's Avatar
"P-Man"
Re: Intermittent power loss- HELP!
Originally posted by PRIMERA_BOY
Hello people,
Welcome along to AF.....Hope you like it here. There's plenty to read, have fun..........now we have a "man and a boy" here to cause trouble
View All My Models Here.
Old 12-10-2001, 09:04 AM
Smile Just an update......
original post..............
Hello all....
Thought I better give an update on what the problem appeared to be.
I had the EGR valve lubricated... I have had no prooblem since.. thats 2 months!
Thank you all for your help..
David.:flash:
