Old 02-03-2003, 06:29 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
parts list for auto to manual conversion
i have a parts list, but it's for an accord so if anyone can help me modify this list i'd be very appreciative. BTW if there is anyone that can get me the parts for cheap please contact me at [email protected]
Parts List:
1. 5 speed transmission
2. 5 speed starter (Don't Need)
3. 5 speed shifter assembly w/ shifter cables
4. 5 speed drivers side axle (Don't Need)
5. 5 speed intermediate shaft
6. 5 speed clutch pedal assembly
7. 5 speed brake pedal arm
8. Clutch master cylinder w/ reservoir
9. Clutch line from Clutch master cylinder to clutch dampener (Don't Need)
10. Clutch dampener assembly (Don't Need)
11. Clutch line from Clutch dampener to 5 speed tranny (Don't Need)
12. Clutch line from 5 speed tranny to slave cylinder (Don't Need)
13. Slave cylinder (Don't need)
14. Clutch
15. Flywheel
16. 5 speed mount
17. 5 speed mount bracket
18. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
19. Recommended: HELMS Service Manual (www.helminc.com) I don't think i'll need this one since i don't plan on doing it myself, unless my dad wants to help.
20. Clutch Cable
Empty Pockets Racing Member #1
Old 02-03-2003, 07:27 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
You shouldnt need any of the hydrolics parts cause 4g trannies are cable. I didn't think there is any difference in the starter from auto and manual but I dont know for sure about that. You also might need a manual ECU but I dont know if that matters or not.
I'm Jordan
My car is the ugliest one on this board
Old 02-03-2003, 08:52 PM
GScivic7's Avatar
what are the hydraulic parts, i know nothing about trannies. and it's a parts list for an Accord so i figured a lot of the parts i wouldn't need
Old 02-03-2003, 08:56 PM
mightytexn's Avatar
Re: parts list for auto to manual conversion
13. Slave cylinder
I think that is the hydrolic stuff you won't need.....you will need a clutch cable too though. If I'm wrong about any of this someone please correct me.
I'm Jordan
Old 02-03-2003, 09:00 PM
GScivic7's Avatar
thanks texn
BTW: how much do you guys think this will run me, not including the tranny.
Old 02-04-2003, 10:47 AM
hotasshonda hotasshonda is offline
Send a message via AIM to hotasshonda
Well I just did this swap this past weekend. I had bought another civic that was stick to do the swap from so it was a lil easier but you got pretty much everything. You don't the the maula axles or ecu or starter. All are the same. You however will have to bypass the sensor that only lets your car start in park and neutral. Also the sensor that doesn't let your key come out unless your car is in park. Its not hard to do at all if you have that helms manual. Heres a list of stuff that you need.
5 speed tranny-clutch flywheel and all that good stuff...
Shifter, shifte linkage, shift rods
clutch cable
pedal assembly w/ clutch pedal (hardest thing to switch)
three mounts that go to tranny (need to be manual)
as well as the bolts and what not...im not sure if the auto ones match up.
There you go...let me know if you have any questions.
Old 02-04-2003, 01:47 PM
GScivic7's Avatar
thanks hotasshonda...i just need to buy the parts, i don't have the mechanical know-how to do something this extreme. I'll probably just sit back and watch while i have someone else do it.
Old 02-04-2003, 03:35 PM
GScivic7's Avatar
1 more question...does it matter what trim level i get the parts from? I'd think it wouldn't matter, but wanna make sure...BTW i'm going to be putting a DX tranny onto an EX engine
Old 02-04-2003, 03:53 PM
I don't think that it should matter as long as it is a D-series trans. If I were you I would try to find a EX tranny but the DX is fine as long at it is a D-series.
Old 02-04-2003, 03:57 PM
mightytexn's Avatar
The trim level doesn't matter when it comes to the tranny fitting, but EX/Si transmissions are geared for better acceleration and the DX/LX 5 speed and Std 4 speed are geared for better gas mileage....If you want more get up and go use an EX/Si tranny.
I'm Jordan
Old 02-05-2003, 01:53 PM
GScivic7's Avatar
i'm getting the tranny for 50 bucks and this car is not going to be modded extensively for a couple of years and it's my daily so i'm just going to get the dx tranny and get better mileage
Thanks for all the help you guys
