Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-02-2003, 08:48 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Exclamation High Flow Cat
I finally put on my OBX high flow cat. It is ALOT better than stock. Apparently, it is illegal to put a igh flow cat on 1996 cars or newer. Did it with the help of my dad and garndpa. It was kinda funny to see one side of my car 3 feet in the air when it was jacked up. After each shift, the beginning of the next gear has a lot more power and the high rpms obviously have more power. I kept the stock cat. cover to make it look like it is stock (because california cops suck and it is a huge ticket) but had to use some washers in between the cover and metal plate to keep it from vibrating. I highly recommend! Exhaust sound did not change (if it did it was minimal).
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 02-06-2003, 02:18 AM
york2600 york2600 is offline
Send a message via AIM to york2600
How much did that end up costing you?
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 02-09-2003, 12:59 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
nice...im thinkin thats my next mod, either that or a new intake manifold. good to hear that it is a mod to use
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 02-09-2003, 01:44 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Just got one myself. It's called a test pipe. OBX call their straight pipes high flow cats or test pipes because it's illegal. A catylitic converter is supposed to filter out engine emissions. Take a look in the " high flowcat ". No filters.:smoker2:
