Old 02-02-2003, 02:49 PM
Dallas_Fl Dallas_Fl is offline
Send a message via AIM to Dallas_Fl
replacing internals
I've been told that I should replace my internals in my engine before I put a turbo on my D16z6. I want to be able to handle 9psi and maybe 12.
what exactlly should I replace and how much should it cost me?(do I have to replace everything?) also do you know any good brand names for these peices. or does brand name even matter.
Old 02-02-2003, 03:19 PM
Saki0's Avatar
Saki0 Saki0 is offline
Send a message via AIM to Saki0
Perhaps a rebuild of your z6 if it has high miles. I think rods and low comp. pistons might be a good start but not sure if those are necessary with 9-12psi of boost. Rods + pistions will cost around $700. There are other methods as well. Im sure others will help you out.
Later
Old 02-02-2003, 04:10 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i think that if your only gonna run at most 12psi just rods and pistons should be enough. you can keep the stock comp ratio since its pretty low already at like 9.2 or.6 i believe, and thats pretty low. if you have extra money, i would suggest a upgraded valve train. i think it will be alittle more than 700, maybe like 900 but idk this is a guess
Old 02-02-2003, 04:18 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Get your self an ems and get it tuned also. You'll be set. Also upgrade your fuel. Like get fuel pressure regulator, fuel rail, fuel pump, and fuel injectors.
Old 02-02-2003, 05:03 PM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
You want to go turbo right? Well my sugestion would be to utilize HI comp pistons and get a smaller boost kit.. You will make the same HP#'s as the guys with 8 5:1 runnin 16LBS if you have 10 5:1 and run 8lbs... You will end up paying less for this setup and can get 8lbs of boost out of a junkyard turbo setup with ease if your straped for cash.
Old 02-02-2003, 05:04 PM
mellowboy's Avatar
Dude trust me its not worth arguin hi compression vs low compression. I think me and u are alone on high compression boost.
Old 02-02-2003, 06:04 PM
Banned
Well someones got to tell them! I knda figured it out myself... Then I saw a crx catapault down the stockton raceway in 9.98! I was like god damn dude what you got! This guys like Im runnin 12Lbs of boost off a JRC with 15 0:1 CR pistons in a h22 and 120 octane fuel.... That sold me... Hey I found a block on the side of the road, anyone know what a R23 is? Its like a 2.2L inline 4... Could be a 2.0L...
Old 02-02-2003, 06:12 PM
mellowboy's Avatar
Its a ford contour svt motor. SO u just found that?
Old 02-02-2003, 06:18 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Okay, when you are gonna be running at least 6 ot 7 psi you better fukin change your clutch cause when that shit is spoolin up it can rip your OEM clutch or whatever u got, get at least a stage 2 Clutchmasters or a Exedy Race Clutch cause your going to go through that clutch like anything!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 02-02-2003, 06:22 PM
mellowboy's Avatar
Yeh upgrading a clutch is always a good idea whether u goin turbo or not. I also recommend getting lsd.
Old 02-02-2003, 07:08 PM
Banned
Yea! I left it on the side of the road thoe... Know anyone that wants it? Its just the bottom end, pistons rods crank... You get the idea.
