Old 02-01-2003, 09:21 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Can this be usefull in the future?
Hi, Today I got Acrylic Cleaner for my brushes and I was just wondering if in the future I mess up on Window frames, will I be able to remove the paint with this cleaner or will it harm the Laquer paint? Thanks
Old 02-01-2003, 09:35 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
shouldn't harm lacquers. although all you really need to clean acrylics (at least from a brush) is water and soap. also dried acrylics usually rub out with compound if put on lacquer.
Old 02-01-2003, 09:36 PM
Camber's Avatar
Ok thanks. I spent 6 bucks on the cleaner so ill make use of it.
Old 02-01-2003, 09:44 PM
935k3's Avatar
935k3 935k3 is offline
window cleaner(Windex)or ammonia will remove most acrylic paints also on the window frames youcsn scrape off the paint witha toothpick. To thoroghly clean acrylic paint from brushes use Nail Polish remover. Acrylics can easilly buffed off of other paints with compound or wax.
