Old 02-01-2003, 12:28 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
Thinning
I gotta thin out some X-1 black tamiya acrylic paint, to make a wash for panel lines.... What kind of ratio are we talking bout? or is this not the right stuff?
Old 02-01-2003, 12:36 PM
daggerlee's Avatar
Something like a 1:10 to 1:20 ratio - should b e almost like water. Thin it with rubbing alcohol. And you shouldn't use X-1, you should use XF-1.
Dan
Old 02-01-2003, 12:37 PM
freakray freakray is offline
AF Modelrater
I hope you are thinning it with the right thinners......
Thin it about 20/1 and it should be OK
AF User Guidelines
Old 02-01-2003, 12:38 PM
Integra14's Avatar
i thought that XF-1 was Flat, in the FAQ guiddy says use GLOSSY, and x-1 is gloss... its just "black" soo idont know??? thanks al ot dagerlee, rubbing alc i see... k
Old 02-01-2003, 12:45 PM
AF Modelrater
If you want to argue about which black, I prefer X-18 for panel lines on darks cars, and XF-19 for light colored cars
rubbing alcohol will work when making a wash, I was concerned that yo would try to use water like I have heard of people doing......
AF User Guidelines
Old 02-01-2003, 12:48 PM
Integra14's Avatar
nah, never tried water, waht does it do? is Rubbin alc gonna EAt away my paintjob?
Old 02-01-2003, 01:00 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
I've read somewhere to use windex to thin water based acrylics. i tried it and it works ok. i guess it has less water tension because of the stuff in it... plain water would tend to stay in one spot rather than run through the panel lines.
Old 02-01-2003, 02:13 PM
daggerlee's Avatar
Humm, I think you should use flat black or at least semi gloss. If you look at a real car, notice how the panel lines don't reflect light back at you.
Dan
Old 02-01-2003, 02:22 PM
935k3's Avatar
935k3 935k3 is offline
Use a 50/50 combination of alcohol and water to thin it. Too much alcohol can attack some paints.
Old 02-01-2003, 05:18 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
if you use a lacquer overcoat becareful, alcohol will eat through it. i suggest you use an enamel wash instead, paint thinner wont affect lacquer.
Old 02-01-2003, 05:43 PM
primera man's Avatar
"P-Man"
Tamiya make a X-20A Thinner which is the best to use to thin down your paint
View All My Models Here.
Old 02-01-2003, 08:18 PM
935k3's Avatar
You must use Testor's because it's the only laquer that alcohol would hurt. Testor's =TRASH.
