Old 01-31-2003, 11:42 PM
djmr2's Avatar
djmr2 djmr2 is offline
Spider webs with Mr. Hobby Paints... :(
doh
so i finally have some free time to work on my s2000.. i load some Mr. Surfacer 1000 into my Airbrush and spray... minor problems at first with low pressure... upped the pressure, sprays fine now. If I modulate my airbrush slighty to spray, i'll get spider webs forming on the parts.
Should i thin Mr. Surfacer 1000?
Should i start spraying off the part and move across it with one pass?
I think it might be the way i'm using my airbrush. Like for small parts i'll maybe just stay in one spot , open the airbrush a little and paint... not like the way i would do a body..
this is my first time using lacquer paints through the airbrush.. so maybe i've to use a diff tecnique that i use with tamiya acrylics..
Also happens a little when i use Mr. Color with Mr. Levelling Thinner.
any thoughts?
Old 02-01-2003, 12:06 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Sprayed Mr. 1000 straight out of the bottle?!
It's supposed to be hand painted. Whatever the brand is, you always have to thin the paint, unless it's specifically made for airbrush.
By how much? You have to figure it out yourself, which suits to your airbrush, pressure and distance to the object.
You can spot spray, or spray in stroke motion. If a part is small, you can simply hand paint Mr. Surfacer.
Some people decant Mr. Surfacer spray to an airbrush, but they say it still have to be thinned to an appropriate thickness.
Hiroaki Fukuda
Old 02-01-2003, 12:26 AM
djmr2's Avatar
icic.. i will try and thin mr. surfacer 1000 next time..
actually even without thinning it sprayed pretty well.. but anything less than 20 psi was bad..
Thing is. i got some spider webs when i used thinned Mr. Color..
dunno i will try agian..
Old 02-01-2003, 12:28 AM
druid_99's Avatar
druid_99 druid_99 is offline
I have to agree with hirofkd, you should first thin the surfacer before you can use it. In order to thin it, you should try mixing it bit by bit with the thinner until the appropriate result is reached. But this also depends on your type of airbrush, pressure and distance.
Old 02-01-2003, 05:11 AM
Veyron's Avatar
Veyron Veyron is offline
Smile
The spider wed condition occurs with lacquer type paints when they are not thinned enough.
Old 02-01-2003, 07:35 AM
sausage sausage is offline
It's alright to thin mr surfacer excessively. I use 3 or 4:1 thinner to surfacer.
Recent stuff:
Singapore scale modeling site at http://machinemess.singaporeanimenews.net
Old 02-01-2003, 09:12 AM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
what do you thin Mr. Surfacer with?
Old 02-01-2003, 09:19 AM
IanLi IanLi is offline
Mr. Color Thinner! :)
Old 02-01-2003, 09:32 AM
daggerlee's Avatar
I just use lacquer thinner to thin Surfacer. But yeah, it's caused by a too-thick mixture, I got some spiderwebs too when I first tried to use it. Can't get Mr. Color thinner because HLJ only sells the Surfacer bottles, not the thinner
Dan
