Old 01-30-2003, 07:36 PM
.porkchop.'s Avatar
.porkchop. .porkchop. is offline
Send a message via ICQ to .porkchop.
Duplicolour Mystify paint question.
has anyone experienced problems with this stuff?
Duplicolour Mystify paint, the kameloen stuff...
i used it on some fujimi models, and orange peel was the result, and I had to spend hours sanding it down..
Now I test painted a spare hardtop from a Tamiya S2K, the same way, and there was NO orange peel at all.
Are the plastics different on each of the model manufacturers?
Old 01-30-2003, 07:41 PM
Sidewinder-03's Avatar
Sidewinder-03 Sidewinder-03 is offline
Did you prime it first?I always prime with duplicolor primer before spraying any duplicolor paint with great results.HTH.
Old 01-30-2003, 07:43 PM
.porkchop.'s Avatar
yes the mystify stuff comes in a set. black primer, the colour changing paint and the clear coat.
but it still gets peel
Old 01-30-2003, 07:47 PM
Try wet sanding the primer with 2000 grit wet/dry sandpaper before applying the color coats.
Old 01-30-2003, 09:37 PM
phatmitsu's Avatar
phatmitsu phatmitsu is offline
Send a message via AIM to phatmitsu
OK... the paint you speak of is a three part system.. the black is a base coat the color is the magic coat and then the clear.. the black does not really work as a primer.. it is just simply a base for the color.. if you spray just the color over say a windshield you can see throught it.. You still need to prime under the black.. Later Rick S..
Old 01-30-2003, 09:52 PM
.porkchop.'s Avatar
OHHHHHHHHHHH!!!!!!! i need to primer under it too??
Old 01-30-2003, 11:55 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
.http://www.automotiveforums.com/scal...icker/itr.html
there's mine that i did with that stuff and I didn't use primer and it came out so smooth, no orange peel at all
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
