Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-30-2003, 05:16 PM
chillinjames chillinjames is offline
Question Maxima top speed ???
I own a 95 maxima SE (Bone Stock ) I like my license so never tried top end on my maxima (have had to 125 mph ) Can anyone tell me approximate top speed of stock maxima ?? @ 125 it felt as though there was a lot of speed left . Thanks and I am not suggesting anyone "open er up" on public streets , That would be very wrong . :smoker:
Old 01-30-2003, 05:55 PM
Pick Pick is offline
It would be good to now if you are manual or auto, but I would guesstimate 137 m.p.h.
Old 01-30-2003, 06:58 PM
Paonessa Paonessa is offline
an se maxima 5 speed will go absolutely no faster than 152 mph. which is pretty damn high
Old 01-30-2003, 09:08 PM
daveauth21's Avatar
daveauth21 daveauth21 is offline
i got an auto and got mines to 132 just the other day but from 125 till it felt like it took forever
Old 01-30-2003, 10:23 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
ive got an auto 97, but mine has the gay gov chip in it and i only got to 120 before it knocked it out of gear
Old 01-31-2003, 04:08 AM
DiS's Avatar
DiS DiS is offline
Send a message via AIM to DiS
mine is 97 also, maximum that I went so far was approx 118, altho owners manual says that I have governor at 128.
97 Nissan Maxima GXE
Auto Trans
Red Injen Racing Division CAI with K&N FilterCharger, Zero1Racing Front Strut Bar
DaRk GrEeN/Beiege Interior
Cleared out taillights/Clear fronts/rewired blinkers and sidemarkers, upgraded grounding...Check my Pics out on my homepage
New purchase BRAND NEW '03 Mazda ProtegE 5-spd
_________________________________________________
Maximum Respect To MaxiManiacs and all Nissan 0wn3r$
Old 01-31-2003, 07:55 AM
y in the hell did they put thoes stupid chips on the gxe model?
Old 01-31-2003, 09:24 AM
so do something about it...
This modification is easy. But beware, it does include mutilation of the factory ECU wiring harness...not for the squeamish.
1.Disconnect negative battery terminal.
2.remove ECU cover from passenger side footwall.
3.Loosen bolt in center of main ECU connector.
4.Unplug main ECU connector.
5.Remove snap-on plastic cover from ECU connector.
6.Locate PINK wire with BLUE stripe. (this wire is located on the right half of the connector when plugged in)
7.Cut PINK/BLUE wire.
8.Reassemble ECU connection.
9.Reconnect negative battery terminal.
10.Drive 140+ mph.
This modification will cause the "check engine" light to illuminate. If you check the codes, you will get 0104 (Vehicle speed sensor fault) and 0504 (A/T control unit fault). So far there have been no drivability problems
associated with this mod.
Enjoy.
Credit: -Ben Garner
Old 01-31-2003, 12:39 PM
crewchief264 crewchief264 is offline
my top speed
before I put on these mods it went a top speed of 137 pretty accurate and I stayed there for a while. (97 5 sp maxima se) I installed a cai warpspeed y pipe OBX cat back, eibach springs kyb agx struts, short throw and strut bar. My top speed I'm not sure of because when I tried this I had no hood on the car, but I touched 140 a lot faster than before and I am postive It will go atleast 150+. good luck and I wouldn't do that on public road.
Old 01-31-2003, 10:26 PM
hey man, bout that ecu mod u were talkin bout, is there no way to tie thoes wires to tos omethin to keep the light off but still take out the chip? or does any1 kno for that matter?
Old 02-01-2003, 12:01 PM
as far as i know that's the only way.
Old 02-01-2003, 03:36 PM
D-sta D-sta is offline
Send a message via AIM to D-sta
135 in my 92
1992 Maxima SE 5-Speed VE Power.
MODS:Stillen HI-FLOW Intake, Tokico Blue Shocks, Eibach Pro-Kit Springs, Stillen Brake Pads, Brembo Rotors, Clear Corners, Suspension Techniques Sway Bar Kit, 2002-2003 Front FSTB, ASP UDP, Warpspeed Performance SS Y-Pipe, Carsound Cat, Greddy SP Exhaust System, SPW Industries HID PLUS 7500K Kit, 2001 Anniversary Edition Shift Knob, Stillen Tie-Down Battery Bar.
Old 02-08-2003, 02:25 PM
smokeydriver smokeydriver is offline
Send a message via AIM to smokeydriver
I got a 97' SE Max, stick. I was going up the jersey turnpike screwing around with a Porsche. I hit 135, and had PLENTY of speed still left. The Porsche hit his brakes hard though, so I did too. GOOD THING- There was a pig sittin' right ahead and would have nailed us both. Oh, and I havn't done a damn thing to my ride!
Old 02-08-2003, 07:22 PM
n1smo's Avatar
n1smo n1smo is offline
Send a message via AIM to n1smo
Re: Maxima top speed ???
You have plenty left... The 95SE is not governed and is drag limited. You should hit 140mph with no problems....
2004 Mazda 3
2003 Maxima SE Titanium Edition
Old 02-09-2003, 11:00 AM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
The reason they put those chips in the cars is based on the tires Ratings, if you have the H rated tires which are economy/performance then you'll probably only get a gov that's rated to 130 or 128 as someone stated.
If you have the z rated tires you can go to the limits of the top end which is what your car can do flat out against drag.
By the way, it should read bk2k3Max, not bk2kmax.
