Old 01-30-2003, 11:15 AM
jusg19 jusg19 is offline
rear trailing arm help
question 1: on the front of the rear trailing arm, there is an arm that you adjust the wheel alignment. I need to know if that arm is the same size on a 91 civic dx and a 91 crx si. the si has rear disc and the dx has drums.
no matter what the answer, does anyone have an extra arm from a 91 crx si passenger rear trailing arm?
thanks
Old 01-30-2003, 12:10 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
yes it will work. probably better than the teg's. just don't forget...the crx is shorter than the hatch. so you will need the teg e-brake cable. other than that, it's a direct bolt on.
you'd have better luck finding the teg set up then crx si....FYI
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-30-2003, 06:49 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
hmmmmmmm it is just the opposite around here ami. Hard to find a teg than a crx there are a ton of crxs up here. alot of them sis
This is the real melt pizzle
Old 01-30-2003, 06:54 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Damn wish i had that problem, i never find any rex's around here...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-30-2003, 06:56 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
if you're referring to the camber bar, I have em (both sides), from an 88 DX. I replaced them with ingalls so the old ones are sitting in my garage...$20 plus shipping?
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 01-30-2003, 07:12 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I think he actually means the arm at the front of the trailing arms that control the toe. That is the only factory part that is adjustable on our cars in the rear.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 01-30-2003, 07:20 PM
EF_LSVtec's Avatar
ic...
AF Bay Area Crew
Retired SOLD 1/08
Old 01-31-2003, 08:31 AM
thanks, yeah the toe bar is what i'm talking about. I have 2 right rear ones from different hatches, but i put the arm from the crx on the left side and it aligned correctly. I didn't have the right rear toe arm from the crx, so i used my hatch one and it won't align, so i think the crx one is shorter.
