Old 01-30-2003, 10:20 AM
bobbyd bobbyd is offline
D16A6 Head on my D15
What will I need to do to put a D16A6 head on my D15? Just swap heads and that is it? Take mine off and put new on or is there more to it? Thanks
"Are you gonna bark all day little doggy, or are you gonna bite?"
Old 01-30-2003, 10:26 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
i think thats pretty much it, did you do the mpfi swap yet?
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 01-30-2003, 10:27 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
HOW MUCH OF AN ALL AROUND POWER INCREASE IS THAT
Old 01-30-2003, 10:33 AM
Not yet bu the engine I got came with everythign to swap to MPFI so that will be coming this Spring. Have you done it?
Old 01-30-2003, 11:13 AM
MyFirst4G's Avatar
I personally have not done it because i have the Si model which was already MPFI, but it has been done by many people on this board, and if the engine that you are getting in spring has the MPFI already, why dont you just wait and do that instead of messing witht the head and stuff now
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 01-30-2003, 11:45 AM
Well, I already have the engine and I figured the head swap would be a weekend job where as the intake could take me a little longer to do. That is why I said I would wait for Spring for that just cause of the car being out of commission for a while. But now I see what you mean, I will have to pull the intake crap off anyway. Thanks, I had a brain fart. I may as well wait and get it all then do it all at once. I need an SI Deistributor, resistor box, and throttle cable yet before i can do it.
Old 01-30-2003, 11:48 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
sorry to say but just over zero the d16a6 cam has a slightly different grind but not enough to feel a difference. the HP gain is with the MPFI conversion
edit: ps, BLU CIVIC i find your all caps entertaining. i understand it is due to work circumstances. it has become my way of identifing your posts
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-30-2003, 11:53 AM
Just over Zero??? Dang it! But in my little D15 I feel every bit of power. :licker:
This winter beater is just too slow and I need more umf
Old 01-30-2003, 12:06 PM
amy@af's Avatar
yea . check it.... the Si has 0.01L. the camshift has a slightly different grind. that's it. the real difference between DX and Si is the MPFI and the tranny. the DX tranny is geared for econo daily driving where the Si geared for more agressive "sport" driving.
get yourself MPFI and a Si tranny and call it good to go
Old 01-30-2003, 12:12 PM
BLU CIVIC's Avatar
調整器
THANX I'M SURE EVERYONE IN THE CIVIC FORUM HAS COME AROUND
Old 01-30-2003, 12:14 PM
Thanks Lady! Man, I need to find a girl friend like you! haha
Ok, well check this out then. I have the whole engine plus the tranny. So I guess I will screw the cam and just replace my dpfi with the mpfi, get a good clutch and replace my 4 speed crap with the 5-speed! Sound like a plan or what? What kinf of gains are we talking with this?
Old 01-30-2003, 12:45 PM
amy@af's Avatar
LOL, be careful what you wish for. after 7 years....i'm suprised i haven't driven jer damn near crazy with my Civic obsession. i'm the kind person you either Love or Hate....and it's generally option 2 as i'm hard to live with
D15B2:
1493cc
4 cyl, 16 valve
SOHC
9.2:1 compression ratio
Power: 92 bhp @ 6000
Redline: 6800 rpm
D16A6:
1590cc
4 cyl, 16 valve
SOHC
9.1:1 compression ratio
Power: 108 bhp @ 6000
Redline: 7100 rpm
Old 01-30-2003, 12:48 PM
haha, thanks Lady!
One more, maybe one more, question. Will replacing the PM6 with my PM5 right now, without the swap help any? Just to help until I do the swap?
Old 01-30-2003, 12:53 PM
amy@af's Avatar
haha, thanks Lady!
you just brought up an important issue. don't mix dizzy's and ecu's. anytime you switch an ecu....switch the dizzy. do not stick in the pm6 until you have the MPFI. it's set up for the programmed fuel distribution. where the dx just spits gas in and it flows through the dual ports as needed. did that make sense. my basic example might has gone
Old 01-30-2003, 12:56 PM
haha, thanks Lady!
That makes sense. I will find a Distributor and do the swap and the ecu at the same time. Any idea where I can find a throttle cable for the swap too? See, I knew I had more questions :P
