Old 01-29-2003, 07:56 PM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
Radio wireup
OK i have a 89 4door which i have a wire diagram 2 but my 91 hatch has NO radio plug on it and i need the wire diagram 4 it i'm trying to solder my 89 plug 2 the 91 hatch plug if it helps its a 91 STD civic Hatch i need a wire diagram really bad....
Old 01-29-2003, 08:06 PM
DJ_Inevitable's Avatar
DJ_Inevitable DJ_Inevitable is offline
try www.the12volt.com they have alot of diagrams...
Old 01-29-2003, 10:16 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
Re: Radio wireup
I know every wire color by heart, let me know if you still need the info.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 01-29-2003, 11:31 PM
radio wireup
yes i still need the diagram and wire colors
Old 01-29-2003, 11:41 PM
91EF3ZC's Avatar
AF Premium User
Re: radio wireup
OK, we will start with speaker wires first:
L/F blue w/green(+) gray w/black(-)
R/F red w/green(+) brown w/black(-)
L/R blue w/yellow(+) gray w/white(-)
R/R red w/ yellow(+) brown w/white(-)
Power wires:
Lights: red w/black
Ground: black silver dots(some don't have the dots)
Accesory: yellow/red
Battery:white w/blue=This is the only wire that would be a different color.
Power antenna: white w/yellow
Old 01-30-2003, 02:23 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
if that plug is to short, the one u are tryin to put back on u should go to like a Bestbuy and buy the reverse harness
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 01-30-2003, 07:33 AM
91EF3ZC's Avatar
AF Premium User
Yes, you can get it there. Metra makes it. I can get them too.
I might have one at work. if I do, would you want it?
Let me know.
Old 01-30-2003, 09:36 AM
radio wireup
Thankx for the effort and the diagrams but my 91 doesnt seem to have the same colors of wires that is in your diagrams. the 91 wire colors dont match what u guys sent me but i will double check my 89 plug and wires DOES match. ALSO there is a small strange plug (5p) but it only has 2 wires in it and it plugs into the back of the cluster the picture i'm attaching should show that OK.... i would like to know what the heck this thing is??? (edit) wiring helped out LOTS works good i have a radio NOW thankx tons now if u could onlyhelp me with that 5P plug
Old 01-30-2003, 05:51 PM
91EF3ZC's Avatar
AF Premium User
Re: radio wireup
is it this plug?
Old 01-31-2003, 12:47 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
My old cluster had that, don't know what it was exactly but when I swapped clusters the one i put in didn't have it, so it didn't get hooked up. I used to know what it was, but forgot for now.
Might I ask what your doing with the cluster? just curious
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-31-2003, 06:40 AM
91EF3ZC's Avatar
AF Premium User
Re: radio wireup
That unit on the back of the cluster is a VSS that ends a speed sense signal to the ECU. The two wires in it power up the unit, and the tow wires exiting the bottom of the unit are the signal wires. this is to the best of my knowlage from doing the JDM SiR cluster swap in my own car.
Old 01-31-2003, 07:36 AM
Tony's Avatar
TLD Member #1
Thats why I have a Speed Sensor Error!!!! oh well, everything works fine, just got a check engine light that comes on sometimes.
Tony
Old 01-31-2003, 08:15 PM
91EF3ZC's Avatar
AF Premium User
My check engine light would come on as soon as i started to decelerate.
It drove me crazy!
2002 galant es radio removal keytosilence Galant 1 07-26-2009 03:09 PM
99 Passat Radio Installation DouganAFife '97+ 0 04-15-2009 08:42 AM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
1994 b-3000 radio removal zoobag General Discussion 1 04-05-2009 05:22 PM
1995-200? Lumina (GM) radio LED conversion saxonmor Car Audio 0 03-01-2009 09:59 PM
