Old 10-08-2001, 04:25 AM
Jay! Jay! is offline
Horizontally Opposed
Side View Mirrors
I think side mirrors are the bane of my existance. Since I finished my MR2, I have re-glued the mirrors back on at least a dozen times with both model cement and super glue. Arrrrgh!!!
I've read tips that say you should drill a little hole in the mirror and the car and use a small piece of wire as a connecting piece, in addition to the glue. So, how do you get the two hole in the same place so they mirror is centered correctly? And what to do on a kit where the mirror glues into the corner of the window, but to the surface of the clear plastic window, not the corner of the door? (the R33 Skyline is like this)
Hierarchy of Subaru:
(Click to see mine!)
Old 10-08-2001, 07:34 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Re: Side View Mirrors
I haven't done this, but here's how I'd address the problem:
Dear Problem,
J/k
I'd drill the door first (with a rather small bit, e.g. 0.6 mm, then I'd place the mirror in the right place and with a needle or something similar put an intentation in the mirror from inside the body. You're with me?
Old 10-08-2001, 08:01 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Or Jay, you could use that same needle and gently (if you're experienced) melt the edges of the mirror to the body and then just touch up the part that melt.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 10-08-2001, 08:19 AM
LauBak LauBak is offline
NO superglue! They will only leave mist on the car or giving trouble to your fingers.
I suggest using some ordinary glue for children's handcraft. It don't hurt the car body and it's enough for mirrors and aero wings.
Old 10-08-2001, 12:34 PM
Guiddy's Avatar
Guiddy Guiddy is offline
My advice would be don't knock the wing mirrors!
Other than that use a rubbery glue like Krystal Klear and a pin.
Glue the mirror on and let it dry Hold it in place whilst lightly drilling a thin hole through both body and mirror, then push a thin strip of metal through covered in glue!
You would need a small Dremel drill for this!
Old 10-08-2001, 02:16 PM
I Don't have a problem with it; it's everyone/everything else in my house that poses the hazard!
Drill it from the back!!! :silly2: :sun: That's exactly what I wanted to know! I just wasn't thinking about it that way, and I couldn't figure how the two holes were ever going to line up!!! Thanks!
Driver side, side view mirror repair patriot457 Ram Pickup | Ram SRT10 2 06-02-2004 09:37 PM
Side View Mirror - Contributions Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 37 04-14-2003 06:21 PM
how do you remove the side view mirrors? PoweredByRice_619 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 03-14-2002 11:30 AM
